Japanese Maple Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 09:00 PM   #1
Rewards Points: 206
Japanese Maple question
Hello, I have a 9 foot japanese in my yard that was replanted 2 years ago. It is doing great and growing and I water it every other day, but I am having a problem. 90% of the tree looks great, but there are some branches where the leaves have dried up and wilted. The branch itself looks to be alive still, but the leaves are crunchy. Any ideas why this is happening and if it's normal? Thanks
joeg679 is offline   Reply With Quote
Old 07-18-2010, 10:36 PM   #2
Where are you located ?
I planted 2 Japanese Maples 2+ years ago
I watered them for a few weeks...haven't watered them since
Old 07-18-2010, 10:40 PM   #3
Rewards Points: 206
Northern NJ. I take it you aren't having any problems with yours.
Old 07-19-2010, 05:47 PM   #4
GardenConcepts's Avatar
Rewards Points: 150
If you water the tree every other day, then you may be killing the tree by over watering. The symptoms are similar with under watering and over watering. With over watering, the leaves will turn yellowish and then die- turning brown and crunchy. Even light, frequent watering is not good for most plants- and Japanese Maples do not like wet feet. The tree would be happier if you watered only once every two weeks- but deep watering- a good soaking.
GardenConcepts is offline   Reply With Quote
The Following 2 Users Say Thank You to GardenConcepts For This Useful Post:
joeg679 (07-19-2010), Ontario Buckeye (07-28-2010)
Old 07-19-2010, 05:49 PM   #5
Rewards Points: 206
Ok, thanks for the help
Old 07-19-2010, 06:18 PM   #6
the Musigician
DangerMouse's Avatar
I was going to make a joke about having him join a basketball team.....
but it seems all is under control here, so I won't make jokes.
They wouldn't be funny anyways.
DM
Old 07-19-2010, 06:26 PM   #7
Rewards Points: 206
LOL. I didn't realize that I missed the MAPLE part in the original post.
Old 07-27-2010, 04:07 AM   #8
Even deep watering once a fortnight is a waste of time. Mulch the surface and never water again. Use woven ground cover or even a sheet of polythene with bark or stones on top to disguise it and hold it down. The amount of water it gets is irrelevant - it needs a constant level of moisture.
The symptoms of over watering and under watering are identical; both will kill roots. Unless you moved it with a rootball of at least four feet diameter and in full dormancy, the roots would also have been damaged when your maple was moved.
At nine feet tall, your maple is obviously quite old and it would take several years to recover from transplanting, even under ideal conditions. You don't say where the damaged leaves are occurring but branches lower down will gradually die back over time.
John
http://www.japanesemapleguide.com
JapaneseMaple is offline   Reply With Quote
Old 07-28-2010, 08:35 AM   #9
Rewards Points: 1,512
Often the larger or higher branches will develop enough foliage to completely shade some inner or lower branches from the sun and then those inner branches will slowly die off.
This appears to be true for Japanese maples and many, but not all species of trees and shrubs.
Old 07-28-2010, 08:54 AM   #10
Rewards Points: 206
I have mulched it. There is one lower branch where the leaves have died and one of the upper branches. The tree is not full enough to block out any sun from other branches. I have stopped watering it, hopefully that will help. Thanks guys.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
