Irrigation Winterize - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 11:55 AM   #1
Rewards Points: 398
Hello,
I had a lawn company come and winterize our irrigation system today, but i'm not fully confident it was done correctly (but then again maybe I don't know any better). I went with a different company this year because the one I went through last year was booked up to December. This only my second year having an irrigation system.
All he did was come to the house, ask me to turn off the ball valve in the basement, unscrew the white end cap, opened 4 zones at once with jumper wires in my box and blew air. Then did the same for the remaining 3 zones.
He didn't touch the outside valves or bleed valves at all. Is this right?
He blew until only air came out, but the contractor last year made the valves diagonal when compete. I can't remember about the bleed valves on the side. Does this make a difference if they were left open? Should I move them to diagonal?
In case you are wondering I only took pictures initially so I could see if this is something I could do myself in years to come and save some money.
Irrigation Winterize-img_2768.jpg   Irrigation Winterize-img_2769.jpg   Irrigation Winterize-img_2771.jpg   Irrigation Winterize-img_2775.jpg   Irrigation Winterize-img_2776.jpg
adgjqetuo is offline   Reply With Quote
Old 11-07-2013, 12:59 PM   #2
Rewards Points: 12
You're fine. The bleed valves are test ports which I've never seen used on my system. The valves are OK the way they are set.
Dan
djlandkpl is offline   Reply With Quote
Old 11-07-2013, 07:32 PM   #3
Oso954's Avatar
Rewards Points: 768
What do you plan on using for an air compressor ?
Most of the pros recommend something in the 50-100 CFM range for the compressor. That is pretty big.
You might want to compare the rental cost +hassle to the full service cost.
Oso954 is online now   Reply With Quote
Irrigation System Supply exiting through House? Ocelaris Landscaping & Lawn Care 2 03-29-2013 11:04 PM
Irrigation tap pipe size jfrank Plumbing 1 01-21-2013 01:42 PM
Pressure Reducing valve and location irrigation branch line ironqqq Plumbing 3 07-14-2012 02:53 PM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
Unsafe irrigation systems....? Why bother? Hossenfeffer Landscaping & Lawn Care 17 08-24-2010 03:14 PM
