Irrigation System - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-12-2014, 11:47 AM   #1
Rewards Points: 70
Irrigation system
In looking at an online vendor, Orbit, they recommend using poly pipe from the main zone feeds from the valve to the zones. I assume that other than the traditional black poly, one can use the newer pex pipe. If yes, Is poly the better way versus traditional PVC?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 03-12-2014, 12:10 PM   #2
Rewards Points: 34
Poly is easier to use than PVC. Just unroll it and go. PEX might be overkill and expensive at larger diameters.
Dan
djlandkpl is online now   Reply With Quote
Old 03-12-2014, 05:14 PM   #3
Rewards Points: 70
Thanks, I just did a price compare and sch 40 PVC came out cheaper.
Old 03-12-2014, 05:23 PM   #4
Rewards Points: 34
Don't forget about your installation labor. You can pull the poly with a ditch witch vs. digging trenches. Plus fewer fittings and less gluing.
Dan
Old 03-12-2014, 05:27 PM   #5
Rewards Points: 70
Its a system for the MIL, her son and I will be doing. His dad was a commercial plumber and builder. Son is now in commercial building. We are the labor, planning to make quick work with a trencher.
Thanks for the input, I assumned that the poly would be way less.
Irrigation system Master Brian Landscaping & Lawn Care 2 04-20-2012 10:24 AM
Irrigation system - normal? Shushka Landscaping & Lawn Care 3 04-17-2012 04:09 PM
Leaking Irrigation System daveclt Landscaping & Lawn Care 0 10-09-2011 02:29 PM
Well pressure boost for lawn irrigation system. wernerp Plumbing 8 08-22-2011 10:33 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
