Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-24-2012, 01:41 PM   #1
Irrigation
Recently I put some ground cover and a few dwarf fruit trees in the same area (sloped). I installed micro sprinklers with a filter and pressure regulator (30 PSI).
I am thinking this is not an efficient design since I am wetting the whole area where the plants are not there.
I have attached photos. Can you please throw your ideas to make it more efficient ?
http://i699.photobucket.com/albums/v...1/P1010084.jpg
http://i699.photobucket.com/albums/v...1/P1010083.jpg
http://i699.photobucket.com/albums/v...1/P1010082.jpg
http://i699.photobucket.com/albums/v...1/P1010081.jpg
http://i699.photobucket.com/albums/v...1/P1010080.jpg
cprao is offline   Reply With Quote
Old 06-24-2012, 01:47 PM   #2
Irrigation
Looks great! You've added tremendous curb appeal! I'm no landscaper but you have a lot of plants there so watering every where doesn't seem like such a bad idea. Maybe someone else can chime in though. Good job either way.
CopperClad is offline   Reply With Quote
Old 06-24-2012, 01:54 PM   #3
Irrigation
Thank you for your nice comments.
Old 06-24-2012, 03:00 PM   #4
Irrigation
How exactly do you expect those plants to get water if you don't wet the entire area?????
Canarywood1 is offline   Reply With Quote
Old 06-24-2012, 03:11 PM   #5
Irrigation
[quote=cprao;950422]Recently I put some ground cover and a few dwarf fruit trees in the same area (sloped). I installed micro sprinklers with a filter and pressure regulator (30 PSI).
http://i699.photobucket.com/albums/v...1/P1010080.jpg[/quote
Sorry for 2nd post,something wrong on site.
Old 06-24-2012, 05:12 PM   #6
Irrigation
Trying to think of putting water just only to the roots, like drppiers for bushers and trees. Is there a way can the same be done for ground cover also ?
Old 06-24-2012, 05:40 PM   #7
sdsester's Avatar
Irrigation
I would think about adding some simple drip emitters for the trees. You might want to put them on a separate circuit so you can water longer and deeper. On a separate circuit you could even add a fertilizer injector for feeding the trees.
Drip emitters come in just about any configuration you can imagine these days ranging from sprayers, misters, bubblers and even rainjet type things. They range from about .5-12gph (gallons per hour). Make sure to allow for tree growth and not plunk the emitters too close to the trunk. Aim for the current and projected drip line.
There is something to be said for the simplicity of the self-cleaning, simple drip emitters about as much fun to watch in action as paint drying. When I designed drip systems I stuck with the simple ones most of the time and in the range of 1-4 gph. I did use a type that was convertible from mister, to drip to off depending on how you configured plastic plugs and they drew about 1-2gph. I just added more for water loving trees and shrubs. With residential water supplies providing 8-12 gpm (gallons per minute) it was pretty hard to run out of water and pressure is seldom an issue with drip unless you have long runs. You can get compensating emitters if this is the case.
I think your annuals and perennials will fill in nicely with the overal spray emitters you have.
sdsester is offline   Reply With Quote
Old 06-24-2012, 06:41 PM   #8
Irrigation
What sdester said+1 that's the way to go for your trees.
Old 06-24-2012, 10:56 PM   #9
Irrigation
I don't think I can put another circuit or another line since the whole area is connected to one valve. To run antother line, I need to break my driveway.
I am looking for this type of irrigation for ground cover:
http://www.irrigationdirect.com/irri...det700-518-100
and the regular 4 gph drippers for fruit trees.
Any comments on this ?
Old 06-25-2012, 10:36 AM   #10
Irrigation
Can't you just use one of these.
http://www.garrettwade.com/solid-bra...ff/p/15T06.02/
Old 06-25-2012, 10:43 AM   #11
Irrigation
I can use them but they still be connected to one controlling valve that is operated by timer.
Old 06-25-2012, 01:32 PM   #12
Irrigation
You would be suprised how many seperate lines you can run off of that.
covering irrigation up Startingover Landscaping & Lawn Care 15 05-23-2012 10:46 AM
Subsurface Drip Irrigation a_lost_shadow Landscaping & Lawn Care 2 03-25-2012 06:32 PM
Water Supply Connection for House and Irrigation jasontf Plumbing 1 06-02-2011 12:01 AM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
Unsafe irrigation systems....? Why bother? Hossenfeffer Landscaping & Lawn Care 17 08-24-2010 03:14 PM
