Interlocking Pavers Around Pool - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-13-2010, 11:00 AM   #1
Question
Interlocking pavers around pool
As mentioned in my title, I have pavers around my pool with sand in between. I'd like to do something to eleviate the sand migrating into the pool mostly by wet feet. I read somewhere I could sweep in dry cement and then wet the pavers down and allow to dry. Is this a suitable solution? I've tried sand with a polymer mixed in, this doesn't seem to help. It sounds like sealing would change the appearance of my pavers, I like them as natural as possible and not interested in "enhancing" the colour. Any other options?
ladygodiva3 is offline   Reply With Quote
Old 04-13-2010, 06:30 PM   #2
GardenConcepts's Avatar
Rewards Points: 150
I've used the polymeric sand around pools with good results. The trick is to water lightly after you sweep the sand in the paver joints- also, keep the height of the sand about 1/16 - 1/8" below the top of the pavers.
If you use cement or mortar in a dry-laid installation, you'll have the mortar pop out in the winter (if you are in a cold winter area).
GardenConcepts is offline   Reply With Quote
Old 04-14-2010, 07:44 AM   #3
Thanx Garden Concepts. Perhaps you're right and I didn't do the polymer sand correctly. I will probably give it a go again this year.
Old 04-14-2010, 06:20 PM   #4
They make a sealer that is a natural finish. You will hardly notice it's even on the bricks. This will help hold the sand in between the bricks. IMO bricks should be sealed anyways.
Bushman is offline   Reply With Quote
Anchoring a gazebo First timer1 Landscaping & Lawn Care 15 07-14-2011 02:59 PM
Pavers over a concrete sidewalk Beckerad Flooring 3 07-20-2010 08:59 PM
First thing to do to pool? tripflex General DIY Discussions 21 09-29-2009 11:55 AM
Question regarding interlocking pavers Ndavidson Flooring 1 08-26-2009 07:47 PM
Interlocking pavers & stair leading to house amdspitfire Landscaping & Lawn Care 6 07-21-2008 03:30 PM
