Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 05-14-2007, 04:38 PM   #1
Insulate Underground Sump Pump Pipe
I have many drainage problems. one I've resolved with a 3 foot deep hole and a sump pump in a container (trash can shaped), holes in it for the water to flow in, filter paper to keep out dirt, 3/4 inch crushed stone surrounding the outside of the container. I was running the pump hose up out of the container and over the top of the ground for 30+ feet away. However, I am in Connecticut, so with freezing temps, I had to bring in the hose so it would not freeze.
Now, I have dug a trench, and parts of this trench is only 18 inches deep. My plan is (so far) use 2" pink styrene board above the pipe to insulate in the ground warmth, along with surrounding everyting with crushed stone for drainage. The sump pump hole did not freeze up, so that has not been a problem.
Are there any other materials to help insulate the sump pump hose at the shallow underground depth?
all replies welcomed.
Basic_Homeowner is offline   Reply With Quote
Old 07-23-2008, 09:32 PM   #2
You could use heat tape where the hose above the frost line.
Mikeee is offline   Reply With Quote
More On This Topic
Hello! My name is Jose Zuniga. I am a professional gardener and today I am representing expertvillage.com. Let’s talk about drainage. Drainage as you know is a very important factor for Azaleas especially when winter approaches us because the roots... Read More »
Hi my name is Paige and we are about to blow the insulation into these walls. We’ve cut our holes and we filled our insulator blower outside. You do leave the blower outside so that it doesn’t get as dusty. This is a two person job. Amelia is... Read More »
Hi I’m Amelia and this is an insulation blower and I am about to load it with some cellulose insulation. Cellulose is a loose film type of insulation. It is often used in attics and other places. The nice thing about it is it is a lot healthier... Read More »
Hi this is Fernando and we are here with Expert Village we are going over how to create a water sprinkling system and specifically creating trenches that your pvc piping would need to lay in. Here you could see the different areas of the yard that has... Read More »
From the water pump to the head gasket and radiator, the cooling system of the car is the heart of the engine. It should be inspected and maintained on a regular basis. By keeping all components of the cooling system running optimally, you can extend the... Read More »
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
Sump Pump Question cibula11 Plumbing 9 04-26-2007 04:28 PM
sump pump issue thorny Plumbing 1 01-31-2007 08:42 AM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 10:36 AM
Sump Pump Kicking On ERIK2173 Plumbing 4 05-05-2006 08:43 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
