Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-26-2009, 05:02 PM   #1
Default installing poly pipe for sprinkler
I am having a asphalt driveway installed soon in NY and will add an inground lawn sprinkler system in the future. Before the paving is done I was planning on putting a length of poly pipe in the ground to cross the 17' width driveway area to a small section of the lawn on the other side of the driveway. Is this a good idea or will weight on the driveway collapse the pipe? Should it be a certain depth?
newgarage is offline   Reply With Quote
Old 10-26-2009, 06:08 PM   #2
It is a great idea. Leave yourself enough room for 3/4"-1" pipe and wire for a remote valve or low voltage lighting if that is part of plans. You could use schedule 80 if you are really worried about crushing it and since you need just 20' or but schedule 40 will be sufficient. Dry fit caps on to the ends to keep it clear. I would be more worried about burrying it below your freeze depth than how far under the slab to put it. You will not be putting enough force directly on it to crush it.
sdsester is offline   Reply With Quote
Old 10-26-2009, 06:12 PM   #3
I would run a pvc pipe across the driveway. You can use fittings to connect the poly pipe to the pvc or you can use an oversized pipe and use it as a sleeve. 18-24" should be good for depth. If there is anything that has to go over there in the future (electrical, water, etc.) now is the time to run it.
teamo is offline   Reply With Quote
Old 10-27-2009, 07:22 PM   #4
Old fart still learning!
I would even spend the extra $4.85 for an extra run of pvc and cap it off just in case for some future project.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
More On This Topic
How a Sprinkler Head Works
How a Sprinkler Head Works by Expert Village
Hi I'm Fernando with Expert Village going over how a sprinkler head actually works and as you can see this sprinkler is connected to the pvc piping. When the pressure comes from the valve which is the water rushes in and fills up the piping it then goes... Read More »
Hi this is Fernando we are here with Expert Village and now we are going over before you actually start installing a sprinkler heads. We have laid down our pvc piping, we have connected our pvc pipes, we have actually done our joining corners and we seal... Read More »
Hi this is Fernando and we are here with Expert Village we are going over how to create a water sprinkling system and specifically creating trenches that your pvc piping would need to lay in. Here you could see the different areas of the yard that has... Read More »
Hi this is Fernando we are here with Expert Village now we are going over cutting the pvc piping and what we have here is the pipe pvc cutters which are a excellent tool to have if budget constraint you not allowing to have it then I suggest that you go... Read More »
So as we have completed our designing, now you have shown to your client. Now she may ask you about the fabric, what I'm going to use it. So basically, you should keep in mind that for which season you are selecting that fabric. Ok, so for that you have... Read More »
Frozen Vent Pipe Ratchye Plumbing 20 02-27-2009 03:10 PM
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-18-2009 01:18 AM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 11:50 PM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 11:43 PM
Help needed 3/4 poly pipe joining sections. TomClarkInLubbock Landscaping & Lawn Care 3 08-13-2007 08:44 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
