Installing Pessure Treated Framed Batten Board Fence. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 11:45 PM   #1
Installing pessure treated framed batten board fence.
As the title suggests I decided to install a pressure treated batten board fence. I was wondering how much gapping should I do. I am using 1x6 which are 3/4 x 5 1/2 actual. I have the posts set up with 8 feet spacing and was gonna do 1 1/2 inch overlap on each picket for a total of 24 pickets every 8 feet. I was wondering if this is enough overlap our to much?
Also I am framing both sides and was wondering would it be easy to just start with one side then start on the other side and just screw them in to finish it off? I am using these brackets to hold all my 2x4x8s. http://www.homedepot.com/webapp/wcs/...atalogId=10053
As of writing this a I did a google search and two people recommended to install at least 1.5 inch overlap, but as I trust the people here more id like to confirm that this is a good idea!
Thanks for any help that anyone might give!
Okami is offline   Reply With Quote
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
Re-grade backyard before installing fence? violetUK Landscaping & Lawn Care 3 03-15-2010 11:58 AM
Board and Batten wood siding Knucklez Building & Construction 39 11-07-2008 11:38 AM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
