Installing Gutter Drain Pipes - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-10-2008, 12:06 AM   #1
installing gutter drain pipes
In two weeks I plan to begin trenching for gutter drains. Just had a few Qs
I'm dealing with 1700sqft of water displacement from my house. I'm doing it in two runs, half the gutters for each pipe.
Now as they meet, should I just run two pipes side-by-side to the exit, or can I "Y" them together? I'm in Ohio, we don't get huge rains very often, but sometimes.
I'll be using the standard s30 4" pipe unless anyone has a better idea?
Any idea about depth? I'm thinking just a foot or two?
john442 is offline   Reply With Quote
Old 04-10-2008, 04:08 PM   #2
I did this last year. I also live in Ohio (NE). Lots of work, but worth it. I did one 4" drain for each downspout with one exception. That one is two downspouts into a single 4'' drain, the second one "y'd" about 15 feet downstream. Every thing drains fine. By my calculations my two 2"x3" downspouts carry just a little less water than the 4" round pipe., assuming maximum flow. Just calculating the combined area. Using that method, a 4" pipe could not handle more than two downspouts, assuming the maximum flow.
Hope that makes some sense and helps.
Bill46 is offline   Reply With Quote
Old 04-14-2008, 10:33 PM   #3
hmmm well I read somewhere a 4" pipe can pass something like 2000gpm at standard pressure, and that it was more than enough to handle upto a few thousand square foot of roof area... one 4" pipe.
I mean it makes sense, when I drive down the road I see only one 4" pipe in the ditch
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 12:17 AM
Collapsed Drain Pipes Piney Plumbing 1 11-09-2006 04:46 AM
