Installation Of Automatic Sprinklers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 10:24 AM   #1
Installation of Automatic Sprinklers
good morning all, i hope this is the right place to ask the question. i would like to install automatic sprinklers at my house. do you know of any links or some advice on how to do this?
thanks
paul
roafamily is offline   Reply With Quote
Old 07-11-2011, 11:11 AM   #2
http://www.rainbird.com/homeowner/de...esignstart.htm
I had a friend use the service linked to above, however he had to adjust a few things as they didn't design the overlap properly
sippinjoes is offline   Reply With Quote
Old 07-11-2011, 04:14 PM   #3
Rewards Points: 320
I would do lots of reading and research online before doing anything. Once you come up with a plan it is not that difficult although it is hard work digging and putting everything in the ground. How much area are you doing? The first thing you have to do is take a pressure and gallons per minute (gpm) reading of your water service to see how many heads you can run on each zone. Buy a pressure gauge and do a test from one of your outside spigots to get a psi reading, then you can figure out the gpm's doing a simple test with a 5 gallon bucket and a stop watch.
teamo is offline   Reply With Quote
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 12:36 PM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 06:56 PM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 07:04 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
