Improving My Shady Lawn - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-07-2008, 04:46 PM   #1
sweaty
Rewards Points: 276
My lawn is always in shade. It is thin, patchy, and weedy. I've worked on it, but with little results. What would you do for this?
sweaty is offline   Reply With Quote
Old 08-07-2008, 07:03 PM   #2
Rewards Points: 1,578
Is it shady due to trees or due to shading from a building? If trees, likely nothing will work since tree roots will suck most of the water from the ground before the grass gets it. You might try reseeding with a shady seed mix if it is only shade from a building. My 2 cents.
Good luck.
bob22 is offline   Reply With Quote
Old 08-08-2008, 06:48 AM   #3
sweaty
Rewards Points: 276
It is shade from trees.
Old 08-09-2008, 02:12 PM   #4
Don't know it all, yet!
The old "dry, shade."
Good call there bob22.
That seems so strange. No wonder most folks don't realize that. Seems like the tree roots would be further in the ground under the grass.
Sweaty, how large a lawn are you talking about? Several choices, some more expensive than others. Maybe one of the creeping fescues, maybe some kind of groundcover, maybe some shrubs and mulch?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 08-09-2008, 03:31 PM   #5
Rewards Points: 1,232
Trim the trees to raise the canopy.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 08-10-2008, 02:47 PM   #6
Still have the issue of the trees sucking the water. Kind of like the big dog on the porch!
Old 08-10-2008, 06:13 PM   #7
Unless you consider cutting the trees down, what is your point? Grass requires more water than trees in any event.
Old 08-11-2008, 07:45 PM   #8
Maybe OP can clarify if this means the entire yard or just a shady corner.
OR
Didn't realize water was the issue in this thread. However, in Georgia watering needs of lawns and watering needs of trees are two different things. And trees get what water there is first. At least according to the University of Georgia.
again
what is your point?
How many trees?
Arborist expense at what cost compared to planting shade tolerant plants?
Master Gardener
Georgia Certified Landscape Professional-UGA/CAES
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 11:36 AM
Is my lawn even worth tilling? joeyboy Landscaping & Lawn Care 5 08-01-2007 09:11 PM
Help with SHOT lawn nsb318 Landscaping & Lawn Care 4 05-09-2007 10:10 PM
My lawn needs major help! J187 Landscaping & Lawn Care 2 08-06-2006 08:13 AM
