Improving My Grading - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-19-2013, 02:06 AM   #1
Improving my grading
I'm trying to improve the grading in our back yard. Due to a flat or sometimes negative grading, water is not flowing away from the house and is causing some of the wood frame of our house to rot. I need to increase the height of the soil against the house but am afraid of putting new soil in direct contact with the house's wood framing (the wood frame extends all the way down to about 2 - 3 inches above the ground). If I put new soil against the wood frame I think I'll just be causing more problems for myself. Is there a way I can safely separate the house frame from the soil with plastic or tar or both? I'll try putting in a French drain later, but my 1st priority is just getting the water flowing towards the right direction. I'm new at this so I'm wondering if this is a job for a landscaper? Any expert opinions are welcomed.
Thanks for any good advice, Steve
teeb57 is offline   Reply With Quote
Old 08-19-2013, 08:19 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,346
Ayuh,.... That ain't gonna work,...
Ya gotta Lower the grades further away from the house,....
Water flows downhill, yer plan just moves the dam back to the house,...
The wood Can't be sub-grade,....
Bondo is online now   Reply With Quote
Old 08-19-2013, 08:31 PM   #3
Thanks Bondo, I was afraid of that
Old 08-19-2013, 08:47 PM   #4
Sounds like time for a French drain. Perhaps with a pump if you can't run it to daylight.
RoyalAcresRod is offline   Reply With Quote
Non-City Grading Inspector? mikegina Landscaping & Lawn Care 0 01-28-2013 02:42 PM
Negative Grading and Soil to Wood Siding Contact Fix? connor016 Building & Construction 14 01-22-2012 10:44 AM
Grading foundation and well windows suggestions newhomenj Building & Construction 10 12-27-2011 09:45 AM
Lawn Grading Cost srinik Landscaping & Lawn Care 8 09-20-2011 01:51 PM
grading for new addition squirrely co. Building & Construction 3 02-19-2010 08:43 PM
