Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 12-04-2010, 01:06 AM   #1
If I put a tree in a wood chipper, can i use the chipped wood in my garden?
I have a tree that needs to be chopped down. I was thinking about asking the tree trimmer to put the who tree in a wood chipper. Does anybody know if I can use these wood chips in my garden on top of the soil. I figure it should look decent. One concern is will it cause a termite problem?
stanlam is offline   Reply With Quote
Old 12-04-2010, 07:01 AM   #2
paper hanger and painter
chrisn's Avatar
It will be fine ,but if green, could possibly leach nitrogen from the soil, so for decoration or walk way it will be fine, for adding to the soil in a garden, not so good.
Old 12-04-2010, 07:17 AM   #3
GardenConcepts's Avatar
You can use wood chips as mulch without having to worry about nitrogen being removed from the soil. If you were to mix the wood chips into the soil you would get a little bit of nitrogen loss from the soil as the wood chips decompose. The whole idea of wood chips being a nitrogen-robbing problem for your garden is a myth.
Chris
GardenConcepts is offline   Reply With Quote
Old 12-04-2010, 08:35 AM   #4
And Still Learning
What type of tree do you plan on chipping?
My Grandfather many years ago used chips from grinding a pine stump and the turpentine was volatile. Not good results and it took a few years for the soil to recover.
Know It ALL is offline   Reply With Quote
Old 12-05-2010, 08:35 PM   #5
Don't know it all, yet!
On top of the soil, yes.
In the soil, not such a good idea as already mentioned.
Termites- It could, depending on your area and where you plan to use them relative to the house. In other works, if you use them a good ways from the house, it could draw them there away from the house. Or it could draw them into your yard from the neighbors. This could be similar to using Japanese beetle traps.
FYI-
Most chips from a tree crew chipper are coarse and irregular. They won't look good in a flower bed but if you wanted to use them in a vegetable garden and till them in at the end of the year probably so. Or if you use them around shrubs at the rear of the yard.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 12-06-2010, 12:51 AM   #6
thanks for your opinions. It turns out the least expensive tree trimmer I can find doesn't own a wood chipper anyway. With the mixed opinions, I think I will just hire the him.
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
repairing damaged wood on older doors, frames, etc (peeling, chipped, etc) joeyboy Carpentry 9 10-03-2007 09:33 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
use of pressure treated wood in the garden bscout Landscaping & Lawn Care 7 06-07-2007 12:23 AM
