Ideas For Ripping Out Small Stumps And Roots? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 06:01 PM   #1
Rewards Points: 163
Ideas for ripping out small stumps and roots?
Any ideas on what might be the easiest way to rip out a bunch of small stumps and roots in my backyard? I'm wondering if a middle buster or something similar pulled behind my tractor might work.
It's a pretty big area that was overgrown with buckthorn. We've ran a brush hog thru and knocked down everything, but now I've got a bunch of stumps and small roots.
Any ideas or thoughts would be appreciated.
Eric
52Caddy is offline   Reply With Quote
Old 04-18-2012, 06:05 PM   #2
MarginallyQualified
Rewards Points: 2,464
Hire a (walking) stump grinder...
or rent one for the day.
Old 04-18-2012, 09:08 PM   #3
Rewards Points: 77
dig out a bit around the root ball and then a tow strap attached to the hitch of a truck will do the trick.
asbury park is offline   Reply With Quote
Old 04-19-2012, 07:50 PM   #4
Stainless Cable & Railing
Talking
Dynomite
M80
Seal Bomb
or
DYNOMITE!!!
cablerailing is offline   Reply With Quote
Old 04-20-2012, 02:31 AM   #5
Too Short? Cut it Again!
Or a chain if they are bigger and more firmly in the ground. Keep an eye on nearby sidewalks or patio slabs. Stop if they start to heave when you pull! You may have to dig down and trim some roots going under them.
In case the roots you are pulling might be entwined with utility services, it is not a bad idea to call your local free locator service to mark and flag for you.
You can treat them with a stump killer but it may take a season or two.
Old 04-20-2012, 07:37 AM   #6
MarginallyQualified
Originally Posted by 52Caddy View Post
Any ideas on what might be the easiest way to...
The man asks for the easiest way and y'all jump in with shoveling and picking and digging and chains and tow straps and well I suppose dynamite can slide by...
Caddy, hire someone with one of these (or rent it):
http://www.youtube.com/watch?v=O_p8E...eature=related
Old 04-20-2012, 08:16 AM   #7
Stump grinders can be fun. I guess I assumed the OP has a bunch of little sapling trunks and roots. A stump grinder seems like overkill for something 3-4" in diameter?
Old 04-20-2012, 09:27 AM   #8
MarginallyQualified
For just one? No doubt.
I've got an area in my yard of about 90' x 30' that was filled with what the locals here call 'volunteer' trees (more like big nasty weeds the way they grow)... I've cut down a bunch already and even got some shady spot grass to grow but more are coming out all of which leaves me with about 20 2-4" "trunks" and all of their roots.
Guess what I'll be doing in early September?
Old 04-20-2012, 10:10 AM   #9
Work Hard, Play Harder
Rewards Points: 212
I've had to remove quite a few stumps.
I get out my shovel and dig around it; I got down 18 to 24 inches around it. As I dig and hit roots that keep me from digging, I pickup my sawzall and cut them; then I work them out of the ground at least a foot or so away from the hole.
Once I'm down the 18-24 inches around the stump; I start giving it a good push and if it is fairly loose I cut it off there. If it is still really strong, I keep going a bit. Eventually I end up with a big knot of wood coming out of the ground.
Then I refill the hole...
coderguy is offline   Reply With Quote
Old 04-20-2012, 10:20 AM   #10
MarginallyQualified
As I dig and hit roots that keep me from digging, I pickup my sawzall and cut them; then I work them out of the ground at least a foot or so away from the hole. Once I'm down the 18-24 inches around the stump; I start giving it a good push and if it is fairly loose I cut it off there. If it is still really strong, I keep going a bit. Eventually I end up with a big knot of wood coming out of the ground. Then I refill the hole...
Cool. btw... which portion of that is the easy part?
Old 04-20-2012, 10:27 AM   #11
Rewards Points: 212
Well, you can't get a stump grinder in everywhere. Sometimes stumps are near something and you can't get the grinder close.
There is nothing hard about it; just a little work. Get out on Saturday morning with a good shovel and you can be done pretty quick.
In my case; I did have everything removed; but I had 5 stumps (of almost 15) that they couldn't get to with the grinder; so I did the above method...
Old 04-20-2012, 08:24 PM   #12
Rewards Points: 150
Wow, thats a lot stumps. My age is showing I guess as I would rent a mini backhoe for one day and dig those suckers out.
Jeeps is offline   Reply With Quote
Old 04-21-2012, 05:26 PM   #13
Rewards Points: 163
Thanks for the replies guys.
Yeah, I was thinking about renting a stump grinder for some of the bigger ones. And a digging out and pulling a couple bigger yet.
I was wondering about the smaller stuff, if anyone has used a subsoiler to rip along side the base and pull out the roots and stump. I'm referring to the smaller ones, 2" max. I figure if I pull that along with the 3600 it should tear up most of the roots, but I'm not sure.
Maybe I'll get one, give it a try and report back.
Thanks again
Old 04-21-2012, 06:42 PM   #14
MarginallyQualified
while you have it there... use it for EVERYTHING
it'll leave the ground nicer than if it was roto-tilled
Ideas for killing azalea bushes clashley Landscaping & Lawn Care 13 10-07-2011 09:38 PM
