I Think I Killed It... - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-19-2007, 10:01 PM   #16
The New Gal
Talking
Yay!
well - all is now well again in my mower kingdom... took it back to sears and exchanged it. i told em it stopped working they said "okay, when'd you buy it?" I told em about a week ago they said, "let's get it exchanged for ya." They didn't ask any questions, and I didn't offer any more info.
Thanks again everyone!!
BTW - I sure wish it'd stop raining for a week or so... so I can get to my backyard. It's like a swamp out there... but i did finish my front yard. That half mowed look was worse than the jungle look!
mochazina is offline   Reply With Quote
Old 07-20-2007, 09:52 AM   #17
Let me guess.... you go alone... without your husband.....
I find all refund/exchange are better serviced to ladies.... base on my personal experience....
KUIPORNG is offline   Reply With Quote
Old 07-20-2007, 10:32 PM   #18
Eibwen
Cool!
Yeah my wife returned a special order shed to Sears once.....
Sammy is offline   Reply With Quote
Old 06-12-2008, 08:04 AM   #19
The New Gal
Question
I'm Baaaack!
Okay, fellas and fell-ettes! You were so helpful last time, I have to ask you another question!
Recently my lawnmower's engine has been acting strangely - running on relatively low RPMs and throwing to one side as it runs. Then sometimes it cuts off after a few minutes of this, other times it keeps going and we are able to cut the yard.
We've changed the air filter, checked the oil and gas levels, and everything else seems fine... My RibDonor's even stumped on this one! Any suggestions?
Old 06-12-2008, 09:29 AM   #20
somthing to do with the Gas supply line I guess
I would think gas is not able to constantly supply to the engine all the time.... may have air blocking the transfer...etc....
Old 06-12-2008, 09:40 AM   #21
Rewards Points: 1,088
Probably gumming of the carb. You can go to a auto parts store and buy some carb cleaner.
Try using premium vice regular. BP/Amoco if possible. It's the best.
handy man88 is offline   Reply With Quote
Old 06-12-2008, 01:18 PM   #22
Rewards Points: 1,910
Did you winterize the mower last fall? If not then probably a gummed up carb. Might have to take apart the carb to degum it well. Maybe you could take it back to your friends at Sears for an exchange again.....LOL.
Old 06-12-2008, 11:51 PM   #23
The New Gal
Lightbulb
Naw, I didn't winterize cuz we kept mowing through the winter! (Did I mention we're in Houston?) But we will try the un-gumming thing.
Thanks, ya'll!! I'll give an update after we get done...
Old 06-13-2008, 07:35 AM   #24
Mold!! Let's kill it!
Rewards Points: 2,012
If there's a fuel filter between the tank and carbuerator, it may be time to change it. Could be starved for fuel from the dirty filter.
Old 06-14-2008, 12:00 AM   #25
Not sure. I put my mowers in the shed from December through March and never winterize. They all start no problem and have for the 9 years I've owned them. I have a greens mower, a reel mower a push mower and a riding mower. I'm really not sure why so many people have problems with starting and running mowers.
My neighbor has been throuh 6 mowers in 2 years. My other neighbor has been through 4 mowers in 3 years. I just don't get it. I change the oil as needed, put in fresh gas, follow the directions and pull the string or turn the key.
KHouse75 is offline   Reply With Quote
Old 06-24-2008, 06:48 PM   #26
Jay123's Avatar
I'd say it's definitely a case of....bad karma.
[IMG]file:///C:/DOCUME%7E1/Jay/LOCALS%7E1/Temp/moz-screenshot-2.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/Jay/LOCALS%7E1/Temp/moz-screenshot-3.jpg[/IMG]
J
Jay123 is offline   Reply With Quote
Old 10-09-2008, 07:10 AM   #27
The New Gal
update!
so it was that "fresh start" thing that was under the gas cap - i'd forgotten about it! oy!! thanks again for all ya'lls help!
Old 10-27-2008, 09:10 PM   #28
Have someone pull the head off of the motor ( that is the part of the motor that the spark plug screws into). You will see the piston under the head. Pour some oil onto the piston and let it set. try to push the piston down with your thumbs. I have seen this oil unfreeze a piston with no problems. On the other, if the mower cranks but smokes then it will need a set of rings.
mhgcsuper is offline   Reply With Quote
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
