I Got A Pond For Christmas And I Have A Question.... - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 01:28 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 510
I got a pond for Christmas and I have a question....
Out of the blue, I got a 700 gallon, 15x8' pond kit for Christmas. My first thought was, I have a very elaborate in-ground irrigation system in my yard with many, many sprinkler heads. I'm guessing there probably isn't a single spot in my yard that would accommodate the pond, that is free of any in-ground piping. Is this going to turn into a crazy project if I attempt to actually put this in? I have no idea about re-piping irrigation systems and whether there needs to balance or certain pitch or whatever.
J187 is offline   Reply With Quote
Old 12-27-2011, 01:57 PM   #2
DIY staff
Rewards Points: 7,174
Moving the tubing or removing a sprinkler head and plugging it should have no noticeable affect on the system.
You might consider a raised bed garden for the pond if digging is not one of your favorite jobs.
I think you will get a lot of pleasure from a pond----very soothing---Mike---
Old 12-27-2011, 02:51 PM   #3
Rewards Points: 56
As Mike said, there should be little or no effect from rerouting the water lines, but I would try to keep the lines that you replace as level as possible, not necessarily for the purpose of the sprinklers, but for the purpose of draining or blowing out the lines, whichever you do in the fall.
The Following User Says Thank You to DexterII For This Useful Post:
oh'mike (12-27-2011)
Old 12-27-2011, 04:23 PM   #4
J187's Avatar
Rewards Points: 510
Thanks for the replies!
Old 12-27-2011, 07:33 PM   #5
Too Short? Cut it Again!
The goal in good irrigation design is to preserve both water pressure and water flow rate. Major theft of both happens quickly with elbow joints and so forth so as you dig things up for the pond try not to make a puzzle maze out of your irrigation plumbing. Keep things as direct as possible. Run new lateral lines if you have to rather than "cutting and pasting" around the pond.
It was never an issue for me designing irrigation systems in California but if you live in a cold climate, you should build in the capability for blowing out the entire system so trapped water does not freeze. Again, a puzzle maze of elbow joints bending around things makes it harder.
You will love the pond. If you need fish to go in it to help keep it clean? PM me. A high school friend's husband's father raises really nice looking Asian Koi. He is always looking for parents willing to adopt the fish.
Old 12-27-2011, 07:35 PM   #6
Rewards Points: 1,574
For those who know ponds: What is done to prevent children from falling in and drowning? Do towns require fencing like for pools? I've read about kids drowning in a 5 gallon bucket; I'm sure a pond would be as potentially dangerous.
bob22 is offline   Reply With Quote
Old 12-27-2011, 09:50 PM   #7
Ironlight's Avatar
Lord. Is that a common snapper or an alligator snapper? If the former then it's the biggest one I've ever seen and I've seen my share. She must be close to 50#.
Ironlight is offline   Reply With Quote
Old 12-28-2011, 04:49 PM   #8
Rewards Points: 768
Why not just dig down a few inches (but still above your lines) and 'build up' the rest of the pond area. Essentially it's a pond that is slightly raised in the back. Most of these ponds include a waterfall and if done with natural stone can look quite attractive.
cibula11 is offline   Reply With Quote
Old 01-06-2012, 01:30 PM   #9
I would definitely put the pond in, I think it will be a great touch to your yard and I wish I had enough space for my own pond. I don't think your sprinklers will be difficult to move. If you were able to put the system in, it won't be nearly as hard to make some slight changes. I hope everything works out in your favor!
Phillies48 is offline   Reply With Quote
Old 01-09-2012, 01:07 AM   #10
You can even make a very pretty pond by simple building a wall around it with those heavy interlocking wall/terracing blocks available at HD or Lowes, etc., and adding an elevated corner with stones and creating a water fall or flow into it (using a circulating pump), and some well placed plantings. I built one of those in my garden dept (in a Lowe's type store) to sell that sort of merchandise and for a nice atmosphere.
bareshiyth is offline   Reply With Quote
Old 01-10-2012, 11:06 PM   #11
I would check your local zoning and maybe call your insurance company to see if that would be a problem. I think the depth would be more of an issue than the size. But if you think someone can fall in it and drown, if that was to happen you should expect a lawsuit, I would get any permit or safety issues taken care of first. The last thing you want is to spend the time installing it just to have to remove it.
tractorfarmer is offline   Reply With Quote
Old 01-14-2012, 06:57 PM   #12
Rewards Points: 6,095
Since it winter, you have some time to do research to see if this is
what you really want. If you want fish you need to be a minimum
of three feet deep in one section of the pond.
We have a koi pond since 1997 and love it, but it's not for everyone.
There are a lot of pond forums, do a search...pond people are good people
and very helpful. Better to research this project before digging.
good luck...
Two Knots is offline   Reply With Quote
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
