Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-12-2013, 04:51 PM   #1
I am wondering why is my yard so low?
I wondering why everytime it rains heavy water sits in my yard? The problem done put a money wrench into my garage build plans.
CJIII is offline   Reply With Quote
Old 02-12-2013, 05:13 PM   #2
Poor grading, now drainage ditch to the street.
Lot's of clay soil there, that will do it.
Old 02-12-2013, 05:19 PM   #3
Are there ways to slove it?
Old 02-12-2013, 05:23 PM   #4
What's on the ground now, in that picture it's hard to tell.
I see all the other yards have grass and your's looks like dirt or concrete.
Someone would really have to be on site to look this one over to figure it out.
Old 02-12-2013, 05:44 PM   #5
Yes its dirt, my neighbors has grass in there yard. My also has a lot of trees in the yard so I think that kill the grass as well.
Old 02-12-2013, 05:46 PM   #6
bbo
build it up with a proper swale for drainage.
note causing problems for the neighbors typically results in remediation for their problems later.
bbo is offline   Reply With Quote
Old 02-12-2013, 06:03 PM   #7
Master General ReEngineer
Bondo's Avatar
Ayuh,... It looks awfully Flat,.... Which way is generally, Downhill,..??
Old 02-12-2013, 06:04 PM   #8
JOATMON
ddawg16's Avatar
Click on the Garage Build link in my signature....the first part of it shows how I did my foundation....if you pour your footings with an 8" stem wall....you have a way to keep water out (and your walls away from the water). You use the dirt that you took out of the foundation to properly grade your yard.
I don't exactly buy into the 'remediation' comment above....if the water has no where to go from your yard, it would be more of a general issue for the whole neighborhood.
If anything...put in a drainage pipe from your back yard to the street.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 02-12-2013, 06:20 PM   #9
It goes down hill, plus my yard is uneven.
Old 02-12-2013, 06:56 PM   #10
Bondo's Avatar
Ayuh,.... If it were Downhill, there wouldn't be any water standin'....
Water Flows, Downhill....
Old 02-12-2013, 09:00 PM   #11
Yes, there could actually be town bylaws that address changes to how rain/water flows
SPS-1 is offline   Reply With Quote
Old 02-12-2013, 09:12 PM   #12
Super Moderator
CJ--a neighbor near by has a similar problem----He sink a sump pit into the yard and pumps the water to the front yard where it can drain to the ditch---
Natural drainage is always the best----but if that is not an affordable option---think about a pump.
Old 02-13-2013, 06:44 PM   #13
Ok how would a pump work?
Old 02-13-2013, 06:57 PM   #14
Super Moderator
You would need to bury a 1 1/2" or 2" PVC pipe under the ground and run it from the new sump pit to a place (front yard) that will drain away---add a sump pump to the pit and an electrical cord---that's it---
Old 02-13-2013, 08:25 PM   #15
Ok thanks! Mike, I will figure a way to fix it.
Suggestions on a broken copper water line that goes to the yard r0ckstarr Plumbing 14 02-01-2013 07:13 AM
Need advice adding power to yard for lights Dornier Electrical 10 12-29-2012 05:46 PM
Dealing with Gophers from a Neighbor's Yard? sd2012 Pest Control 24 12-21-2012 06:24 PM
Front yard decorating tips jay_chua Landscaping & Lawn Care 1 03-10-2010 08:00 AM
Well Water ? - No water at yard hydrants... but do have water in house mntnvew Plumbing 73 01-11-2010 09:45 PM
