Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 12-05-2011, 02:09 PM   #1
Hunter Pro-C winterizing
Hi all, i have a Hunter Pro-C system installed and would like to winterize it. Can you please give me some pointers on what to do?
yuriy128 is offline   Reply With Quote
Old 12-05-2011, 10:27 PM   #2
Msradell's Avatar
It's actually quite simple. First you need to isolate the water supply to the system and then use an air compressor to blow the water out of the lines. You don't need to do anything to the controller or the valves. Most systems have a place to attach the compressor either near the water shut off or at the backflow preventer.
Msradell is offline   Reply With Quote
Old 12-06-2011, 07:49 AM   #3
Thank you! I got quoted $100 to do this job, but would rather do it myself.
So there is no need to open any valves? Just use the compressor to blow and thats it? Also how powerfull of a compressor do i need? i saw HD had some for sale this week for like 50$.
Old 12-06-2011, 09:03 AM   #4
Super Moderator
The reason that you pay the big bucks to blow out the system is that you need a BIG compressor--the kind that tows behind a truck--I don't know the size--but it takes a lot of CFMs to clear those lines.
oh'mike is online now   Reply With Quote
Old 12-06-2011, 12:37 PM   #5
Msradell's Avatar
I know a lot of people say that it takes a lot of CFM's but I've done it many times with just a small compressor with the 2 gallon tank and never have had any problems. I only open the valve to one zone at a time so I don't try to blow up every zone at once. I'm sure I don't get the system as dry as they do with the big compressors but it works.
Old 12-06-2011, 09:20 PM   #6
Super Moderator
I'm not all that savvy about the systems---so your knowledge (real world) trumps mine (theory)
Martec or Hunter Pacific Brand Fans (Australia) jen.c Electrical 0 01-18-2011 12:23 AM
Hunter Thermostat Model 44860 Heat Pump Emergency Heat Does Not Work On Auto stvnhdmpa HVAC 8 12-08-2010 06:44 PM
Hunter Fan/light and dual switch wiring nashua Electrical 2 01-02-2010 11:40 AM
Hooking up a hunter thermo from an analog carrier nelsonmay HVAC 5 09-29-2009 10:39 PM
New hunter 44860 tstat mndevildog HVAC 1 07-16-2008 10:24 AM
