Hunter PGP Sprinkler Leak - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 12:38 PM   #1
Rewards Points: 29
Hunter PGP sprinkler leak
Hi, a bunch of my Hinter pgp rotary sprinklers are leaking, looks like from underneath, please see pics. How do i fix these?
Hunter PGP sprinkler leak-image-642861465.jpg   Hunter PGP sprinkler leak-image-131305075.jpg
yuriy128 is offline   Reply With Quote
Old 05-03-2012, 04:22 PM   #2
seansy59's Avatar
Rewards Points: 258
If its coming from between the riser and the base, then its the wiper seal. You can replace these by taking the head out out taking it apart. But I would just replace the head since they are only about $10 each, and the seal will probably cost $6-$8 by time you add shipping.
If its coming from underneath the screw cap and body, they will also need to be replaced, unless tightening helps. My theory is, if I have to dig it up, I might as well put a brand new one in. It's as simple as replacing a light bulb.
seansy59 is offline   Reply With Quote
Old 05-03-2012, 04:25 PM   #3
Rewards Points: 29
thanks a lot, do you know the best place to get these?
Old 05-03-2012, 04:36 PM   #4
seansy59's Avatar
Rewards Points: 258
Ebay sells them for $11 each, free shipping.
http://www.ebay.com/itm/HUNTER-PGP-A...#ht_3812wt_770
Also check your local Home Depot. Some Home Depot's have them in there store.
Old 05-03-2012, 04:37 PM   #5
Rewards Points: 29
great! thank you so much!
The Following User Says Thank You to yuriy128 For This Useful Post:
seansy59 (05-03-2012)
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 10:15 AM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
Hunter MP rotator sprinkler nozzles MeatHead Landscaping & Lawn Care 2 09-20-2010 08:10 AM
PVC Sprinkler Leak at T Joint D2D2 Landscaping & Lawn Care 3 08-26-2010 03:57 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
