Hunter MP Rotator Sprinkler Nozzles - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 08:40 PM   #1
Hunter MP rotator sprinkler nozzles
Does any body have exspeariance with Hunter Mp rotor sprinkler nozzles? What did you like? What did you dis-like? How much longer did you have to run each sprinkler zone in order to get the same amount of water onto the grass, as compared to conventional spray heads?
MeatHead is offline   Reply With Quote
Old 09-19-2010, 09:39 PM   #2
I do know some things
I haven't used them, they were just starting to come to the market right before I left the irrigation world. If memory serves the original sales pitch was that the nozzles were matched closer to rotor nozzles so that they could be used on the same zone as a rotor.
In typical situations fixed sprays apply water to a smaller area at a faster rate thus making the combination of rotors / sprays on the same zone difficult to manage.
From looking at the nozzle performance chart a fixed spray puts down about 1.6 inches of water per hour vs the mp at around .4 inches per hour. You can do the math and determine how much longer it will take.
I haven't been involved with irrigation in 4 years, the technology may have changed so take my info for what its worth.
swade is offline   Reply With Quote
Old 09-20-2010, 09:10 AM   #3
Rewards Points: 79
Just FYI - my buddy across the street just had a system put in using the Hunter rotors and as yet I have heard no complaint. He has seven zones and we just finished laying 33 pallets of sod two weeks ago. Of course, whether the Hunters hold up and are consistant is the question. - Too soon to tell really - tho he usually researches fairly thoroughly.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Hunter Fan/light and dual switch wiring nashua Electrical 2 01-02-2010 11:40 AM
Hunter 44668 Thermostat - Heat won't turn off ToneyRes HVAC 9 10-18-2009 09:50 PM
Hooking up a hunter thermo from an analog carrier nelsonmay HVAC 5 09-29-2009 10:39 PM
New hunter 44860 tstat mndevildog HVAC 1 07-16-2008 10:24 AM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 10:58 PM
