How To Stop Bank From Washing Away - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 07:31 PM   #1
Unhappy
How to stop bank from washing away
We have a creek on our property. It is on the lowest level of our property. A bank leads up to our home. The top of this bank is about 2-3 feet from one side of our home and is washing away. This bank is covered with trees and vegetation. What do we do? I have been reading about retaining walls etc but do not know what is the best course or if we need a professional. I am hoping we can do this ourselves as we have the time. Please help.
Godislove555 is offline   Reply With Quote
Old 02-26-2011, 08:32 PM   #2
Rewards Points: 558
You would have to build a retaining wall. Sure you can do it yourself which will take time but if you want it done in a timely fashion then hire professionals who do this kind of work. Get at least three quotes for this type of work and please go see their previous work so you are satisfied with the outcome.
epson is offline   Reply With Quote
Old 02-26-2011, 08:36 PM   #3
How do we build the retaining wall
Can you give me some detailed instructions on building a simple but effective retaining wall - whether to use wood or concrete and how to do it including drainage, gravel etc. I want it to the an effective retaining wall as this effects the integrity of our home. Thanks so much for your time.
Old 02-26-2011, 08:40 PM   #4
DIY staff
Rewards Points: 7,174
Where are you located? The construction will be different if you have frost to consider.
Old 02-26-2011, 08:42 PM   #5
Winder, Ga.
Winder, Georgia about 40 miles northeast of Atlanta, Georgia
Old 02-26-2011, 08:49 PM   #6
Rewards Points: 558
Before you start anything there might be code issues because you are dealing with wet lands, actually it probably comes under federal regulations. So, the place to start is with your local AHJ (authority having jurisdiction) contact them to see if any work would be acceptable. My guess is it would not, or if possible, the process will be difficult. Iím not an expert on what the rules and regulations are but I would bet that they would be sticklers for details.
Old 02-26-2011, 09:01 PM   #7
I don't understand why building a retaining wall will be an issue. Our home has been on this property for 20 plus years and we have made many improvements including an asphalt road. This is simply to keep the bank from washing away
Old 02-26-2011, 09:12 PM   #8
Rewards Points: 558
Like I said there might be code issues its better to check then find out the hard way. It doesn’t matter that your home was there for 20 years. The creek was there longer than your home and that would fall under federal regulations.
You also wanted some ideas of a retaining wall take a look into using gabion baskets which are galvanized wire baskets in a rectangular form which get filled with native stones. The baskets get wired together to form a flexible yet monolithic wall system. The geometry of the wall will depend on the site conditions, flood elevations and related design constraints. They are a very economical solution for retaining walls. Maccaferri is leading manufacturer. Check out their website for design recommendations.
Here is their link: http://www.maccaferri-northamerica.com/gabion.aspx
Old 02-26-2011, 09:27 PM   #9
Thanks for your help.
Old 02-26-2011, 09:30 PM   #10
Rewards Points: 558
No problem. I hope it did help you decide on what to do.
Old 02-26-2011, 09:34 PM   #11
Learning by Doing
Leah Frances's Avatar
EPson gave VERY good advice. I would start by contacting your county extension office. They will be a good clearing-house for the information you need - you may or may not fall under wetland regulation - and how best to deal with the erosion.
IN GENERAL, localities have a goal of reducing erosion and runoff. They are going to be on your side, they are just going to want to make sure it's done right.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-27-2011, 10:30 AM   #12
There is probably no meaningful help here based on the limited information of your property. Photos of the area would be a good place to start, but much more would be needed.
On the issue of permits, Winder has a Planning Dept with a webpage. I think it unlikely that there will be a lot of red tape for a small retaining wall, but Winder does have a permit for Land Disturbance. You may need this permit. Through links at the website, there is information available with interactive parcel mapping and also Flood mapping panels.
http://www.cityofwinder.com/index.aspx?page=106
pls8xx is offline   Reply With Quote
The Following User Says Thank You to pls8xx For This Useful Post:
oh'mike (02-27-2011)
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 03:13 PM
Fire Stop jamiedolan Remodeling 7 03-03-2009 12:39 PM
Hinge Pin Door Stop exterior dws General DIY Discussions 5 02-17-2009 10:58 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
