How To Rough Up Concrete Sidewalk - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-19-2009, 08:52 PM   #1
How to rough up concrete sidewalk
We have a concrete sidewalk that the 'finishers' did not feel needed a good brooming - we live where we got 88+ inches of snow this year. This sidewalk is just too smooth and my husband is threatening to tear it up and redo it. I want to first investigate if there is an alternative way to rough up the surface. The sidewalk in front of my quilting studio is perfect - no slippery sidewalk.
What can I suggest to him before he gets the sledge out and gives himself a heart attack.
Thanks,
Mary
maryj is offline   Reply With Quote
Old 03-20-2009, 04:31 PM   #2
Don't know it all, yet!
Sidewalks/concrete aren't my specialty (of landscaping) but I'm thinking that you could put a resurface coat on it then broom that. That is the process used for when concrete gets spalling (flaking), small cracks, etc. It's just a very thin coat, about 1/16 inch to 1/4 inch and usually smoothed out with a squeege but I don't see why you couldn't broom it just as well. HD, Lowes sell it as I'm sure your local building supply would. As best as I remember it's about $20 for a bag that covers about 50 sq ft. Or there are other products that go on a little thicker.
Maybe someone else can add something and I'll learn an extra way.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 03-21-2009, 09:30 PM   #3
Rough it up!!
I don't normally do anything with construction of sidewalks, but an idea I had when I read this posting was: Get a bag of concrete (same color) mis some pebbles in with it, and lay a coat over your existing concrete!! Just a suggestion.
TxHeart_4uAC is offline   Reply With Quote
Old 03-26-2009, 05:56 PM   #4
If she's living with 88+ inches of snow that's a lot of freeze and thaw and moisture and it will just spald off. I'd ask around and find a good concrete finisher and see what they. If they say acid wash I'd keep looking. There are some mechanical methods but I'm not so sure you'll like the look.
The only other option is that you could paint it and put a lot of abrasive in the paint. You'd probably need to do it every year or two but they do have a concrete gray color that's a dead ringer for the real thing.
Dugger52 is offline   Reply With Quote
Old 09-08-2009, 09:12 PM   #5
Slippery sloap
You can always buy a good concrete paint and mix some sand in with it.
How do you clean your walks? Broom, shovel, snow blower? This is a variable you need consider when deciding your plan of action.
Stamped, aggregate and tile sidewalks are for warmer climates with no snow and ice. In the future, just a good old fashioned broom finish on your concrete is best for winter conditions.
Regards and good luck
tuco44 is offline   Reply With Quote
Old 09-09-2009, 08:41 AM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
is it actual sidewalk that runs the frontage of your property? or just a walkway from front door ?
if walkway, you could try something like this http://www.nonslipcoating.com/concrete.htm
or this http://www.interstateproducts.com/nonslipproducts.htm
not sure if it would be practical for actual sidewalk
Mr Chips is offline   Reply With Quote
Tags
concrete , sidewalk , slippery
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Pavers over a concrete sidewalk Beckerad Flooring 3 07-20-2010 08:59 PM
How to smooth a rough aggate concrete floor lotstodo Flooring 1 08-18-2008 09:23 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-24-2005 11:40 PM
