Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 11-25-2012, 03:58 PM   #1
How to remove a timber post without having the need to use a breaker?
Hi Guys.
I am just wondering if their is a tool you can use to remove timber or concrete posts from the ground with having the need of using a breaker?
Can anyone help?
Links removed
dave19london is offline   Reply With Quote
Old 11-25-2012, 04:06 PM   #2
Go back and reread your post, it's confusing.
Breaker?
Here's a bunch of different post pullers.
http://www.bing.com/images/search?q=...ller&FORM=IGRE
imautoparts (11-25-2012)
Old 11-25-2012, 04:08 PM   #3
Kango, breaker... that breaks concrete??
Old 11-25-2012, 05:10 PM   #4
It's never easy removing posts. What does this post support, where is it at on your property?
BTW it is really worthwhile to click on that post puller link. I never knew there was such a variety.
imautoparts is offline   Reply With Quote
Old 11-25-2012, 06:25 PM   #5
Master General ReEngineer
Bondo's Avatar
Breaker?
Ayuh,... 'cause he's spammin' 'is website....
Old 01-25-2013, 02:52 PM   #6
Take an old tire or rim, hook a chain at the base of the post above the ground.
Run the chain over the tire standing up next to the post.
hook the other end of the chain to your truck.
The tire acts as a fulcrum, and the post with enough pull will come right out
maple man is offline   Reply With Quote
Tags
fence post, fence post removal
3 way switch trips breaker over night Hazelberg Electrical 5 09-21-2012 10:34 PM
GFCI Hot tub breaker nick26 Electrical 16 08-10-2012 08:48 AM
Added new breaker, no garage lights now. lum1nes Electrical 8 08-04-2012 08:50 PM
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 05:54 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 08:06 PM
