How to remove a timber post without having the need to use a breaker?
Hi Guys.
I am just wondering if their is a tool you can use to remove timber or concrete posts from the ground with having the need of using a breaker? Can anyone help? Links removed |
Go back and reread your post, it's confusing.
Breaker? Here's a bunch of different post pullers. http://www.bing.com/images/search?q=...ller&FORM=IGRE |
Kango, breaker... that breaks concrete??
It's never easy removing posts. What does this post support, where is it at on your property?
BTW it is really worthwhile to click on that post puller link. I never knew there was such a variety. |
Take an old tire or rim, hook a chain at the base of the post above the ground.
Run the chain over the tire standing up next to the post. hook the other end of the chain to your truck. The tire acts as a fulcrum, and the post with enough pull will come right out |
| All times are GMT -4. The time now is 03:35 PM. |
