How To Remove Metal Fence Posts? - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-04-2012, 03:29 PM   #16
I know this is an old thread but wanted to share my experience.
Tried the jack, but could not get it to work because of unlevel ground. Tried a long 1 inch iron pipe as a lever, that just bent.
Used the pressure washer with the narrowest setting nozzle. Boring with the water on three sides of the post. About 5 minutes per post and out they came. All were about 18 inches deep in Georgia clay.
Thanks for the tip on using water pressure.
RichPhillips is offline   Reply With Quote
The Following User Says Thank You to RichPhillips For This Useful Post:
PaliBob (04-04-2012)
Old 04-04-2012, 03:47 PM   #17
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The HFT solution is to use a 3-1/2 Ton Farm Jack:
http://www.harborfreight.com/48-inch...jack-6530.html
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-04-2012, 04:54 PM   #18
Rewards Points: 77
I pulled out 3 this weekend in about 15 minutes with a spade shovel. SO you may jsut dry digging down to see how really "sunk" they are. Mine were about 2 feet deep and one foot wide footings. I guess I may have just gotten lucky, but a little digging and rocking the posts back and forth had them out fast.
Doing things almost the right way...
Double is offline   Reply With Quote
Tool to remove metal? darsunt Building & Construction 5 05-16-2008 03:01 PM
How do you remove plastic coupling nut and washer from braided metal connector? tony__s Plumbing 3 05-15-2008 10:15 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Wet Anchor mounting of fence posts ? Sven Landscaping & Lawn Care 2 12-26-2007 12:09 PM
Height of Fence = Height of Posts Necessary Dallas Building & Construction 2 11-05-2007 09:47 AM
