Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-02-2008, 10:40 AM   #1
How to remove metal fence posts?
A few years ago I had a landscape company install two large trees that were spaded in. They drove in three metal t-bar fence posts around each tree at an angle and anchored the trees into these with Arbor-Tie. I have long since cut the Arbor-Tie from the trees, but am left with these fence posts sticking out of my yard. These things were driven deep and my yard is clay heavy. I cannot get these things to budge by hand, even after a hard rain when the ground is soft. The landscape company I hired has changed owners & names since then so they don't want to deal with it. They suggested cutting them at ground level with a sawzall. Just what I want...cut metal posts just beneath or at ground level with kids running around. I'm sure if I had a backhoe I could tie a chain to them and rip them out, but i'm just your typical homeowner with no heavy duty equipment like this.
sk8z is offline   Reply With Quote
Old 09-02-2008, 10:54 AM   #2
the Musigician
DangerMouse's Avatar
tow chain on yer pickup trailer hitch? you know anyone with a winch on their truck? or dig a foot down then sawzall and recover?
DM
Old 09-02-2008, 11:14 AM   #3
I guess your only bet is to dig around the posts and see if they budge. I had that between me and my neighbor, kids were going back and forth so I had to remove it. I dug maybe a foot or a little bit more and I was able to remove it by hand (after some wiggles).
I am not sure how deep your is going, but it would not hurt to try.
good luck.
rabih_00 is offline   Reply With Quote
Old 09-02-2008, 03:41 PM   #4
Kap
Mowing my life away.
http://www.gemplers.com/list.aspx?SK...ller|974864725
Kap is offline   Reply With Quote
Old 09-02-2008, 03:43 PM   #5
Kap
This may be the most economical, and you could easily get a bumper jack from a salvage yard.
http://www.gemplers.com/product/M119...-T-Post-Puller
Old 09-03-2008, 03:40 PM   #6
Indentured Servant
levers are the key.
jackpine is offline   Reply With Quote
Old 09-06-2008, 04:05 PM   #7
Don't know it all, yet!
Check with your local tool rental company. I was going to suggest the jack until I read down and saw that Kap beat me to it.
Or, get two shovels, you and a helper get one on each side, wedge the post between you and lift up together. When you try to pry up by yourself, the post just pushes away; when two of you push together, against each other, you can work up the post inch by inch until it works loose. Don't try to get too deep of a bite, just enough to bite against the post and move it just a little. As a parks department landscaper, I find that this works quicker than going back to the shop for a tractor. Just my experience that proves "old age and treachery" beats "youth and vigor."
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 09-07-2008, 05:16 AM   #8
Kap
And then there's the old age & wisdom method: give 20 bucks to youth & vigor and have them do it.
The Following User Says Thank You to Kap For This Useful Post:
Ravenworks (04-04-2012)
Old 09-07-2008, 10:32 AM   #9
Old 09-10-2008, 10:05 AM   #10
STAFF
BigJim's Avatar
One way to get the posts up would be to take an old car tire and rim and chain. Hook the chain around the post at the ground, stand the tire and rim as close as you can to the post, put the chain over the tire and hook the chain to your truck and pull slowly. This will pull the post up and without much effort.
BigJim is offline   Reply With Quote
Old 09-11-2008, 01:26 PM   #11
Enormous Member
skipjack's Avatar
I was going to suggest using a car jack from your trunk. If you can rig up a board or something and attach it to the post solidly for the jack to get under and push.. and maybe a plank for it to sit on top of so it doesn't sink in the grass while you're cranking.
skipjack is offline   Reply With Quote
Old 09-13-2008, 11:58 PM   #12
Use a long metal bar, pipe, or sturdy piece of wood.
Set the bar on the ground next to the post. If the bar is 8 ft. long, then at the 7 ft. part of the bar, use bailing wire wrapped many times (10) around both the fence post and the bar.
Then lift the end of the bar and the post will come right out. The bailing wire keeps the bar attached to the post and you get a lot of leverage.
Billy_Bob is offline   Reply With Quote
Old 09-15-2008, 11:37 AM   #13
Learning by Doing
Leah Frances's Avatar
Get a 8 foot length of PVC pipe wide enough to cover the metal stake and grab your hose. Put the PVC pipe over the stake. Put one of those 'firehose' type nozzels on the hose. Push it down the pipe until it hits the ground right next to the stake. Turn the water on and let it go to town. Now-and-then push down on the pipe/hose/stake so the hose can work down a little deeper, and wobble the stakes as much as you can.
Or, if you don't love the potential for getting wet and muddy. Pay someone else to do it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-09-2009, 08:15 PM   #14
Just pulled 5 6foot posts with a bumper jack and 2 feet of chain
urbanfarmerdude is offline   Reply With Quote
Old 08-16-2010, 10:40 PM   #15
I had the same issue with getting t-posts out and what ended up working was a comalong. You can get one for like 30 bucks.
MadeleineLB is offline   Reply With Quote
Tool to remove metal? darsunt Building & Construction 5 05-16-2008 04:01 PM
How do you remove plastic coupling nut and washer from braided metal connector? tony__s Plumbing 3 05-15-2008 11:15 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Wet Anchor mounting of fence posts ? Sven Landscaping & Lawn Care 2 12-26-2007 01:09 PM
Height of Fence = Height of Posts Necessary Dallas Building & Construction 2 11-05-2007 10:47 AM
