How To Rebuild Tecumseh Electric Start? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-12-2009, 12:25 AM   #1
Down To Earth
asian432003's Avatar
My Tecumseh electric start is not working properly, all it does go in hit the flywheel and won't turn the flywheel.
Is anyone know what is wrong with it? How am I rebuild the electric start to make it works?
Very, very appreciate your help !!!
asian432003 is offline   Reply With Quote
Old 09-12-2009, 10:21 AM   #2
Safe, Most of the Time!!
brokenknee's Avatar
Does it make a high pitched whining sound? If so it is most likely your starter drive, which usually is not to big of job to replace. Or does it make one solid click and then do nothing, that would be most likely your selinod and that too is not a big job.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 09-12-2009, 10:29 PM   #3
Down To Earth
Yes, It does make a high pitched noise !!!
I took it apart and clean the carbon inside ....Put it back ...but no luck.
How do i fix that starter drive? Can you help?
Thanks in advance!!!
Old 09-13-2009, 06:34 PM   #4
brokenknee's Avatar
You normally just replace the starter drive. This usually means you have to take your starter apart to install it. I am not sure about your particular starter, but I have been able to purchase just the starter drive in four wheel ATVs.
You may also want to price out the cost of a new starter and see if it is cost effective just to replace the drive.
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 09:34 AM
adding electric start to Makita generator Mr Chips Tools 6 02-16-2009 08:55 PM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 10:21 PM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 08:05 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 12:39 PM
