How To Re Do A Brick Patio - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 08:53 PM   #1
how to re do a brick patio
so in my back yard there is a 20 x 15 swaur UGLY as hell oxford brick patio.
Its ugly because its masive weeds all in the cracks and its bumpy and wavey.
I removed all the bricks and under it is about 2 inches of lime stone screening and thats it straight soil under it.
what is the best way for me to deal with this?
1. remove just the lime stone screening and store it, dig up the soil an addition 4" and then fill 4" crushed gravel + replace the 2" lime stone compact and lay brick?
2. just scrape up the lime stone get it nice and loose re level it, compact and just replace the brick
i ask because the guy at home depot says there is no real need for gravel, just screening, and if thats the case i dont want to dig through all this...
any suggestions advice?
i am thinking about renting a tiller to break up all the compacted screening either way...
thanks
hi09 is offline   Reply With Quote
Old 05-01-2010, 10:30 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Clay brick pavers or interlocking concrete pavers because there is not way to lock the clay pavers together.
There are many different methods to lay clay pavers. If they are concrete pavers, they should be laid in a uniform 1" thick bed of uncompacted sand. After that set the pavers, spread a layer of fine sand (masonry sand) and vibrate the patio with a plate vibrator to leven out the surface and interlock the pavers into a solid surface that provides stability
Dick.
concretemasonry is online now   Reply With Quote
Old 05-02-2010, 07:48 AM   #3
In my neck of the woods, which is Michigan where the ground freezes,
I excavate and install 7 inches of compacted base, varies by location, we use similiar to a 23A. On top of that I install 1.5 inches of sand. I use what is called 2NS sand. That is compacted as well. Screed/level the compacted sand and then lay the pavers. Compact the pavers using the plate compactor. You may have to use a sheet of thin plywood under the compactor to keep brick from chipping. I have used this for clay and concrete. Use jointing sand to sweep over the patio to lock the pavers in place. Try and fill the joints all the way. Digging sucks especially by hand but it's worth it. Good Luck
PS Go slap the guy at home depot.
If you don't have time to do it right, then you must have time to do it over!!
Bushman is offline   Reply With Quote
Old 05-11-2010, 05:32 PM   #4
Rewards Points: 410
Here's a link to a DIY paver install with pics. click on the DIY column.
http://www.paveloc.com/
Lots of info on this site also use the search on this site as this subject
comes up fairly often.
If the box stores told you just how much work is involved to do it right
they would never sell any brick ( but mostly they just don't even know).
Installers around here get $10.00 and up a square foot ( labor only) so you
can save a lot doing it yourself .
High Gear is offline   Reply With Quote
Concrete Patio with brick ribbons vactek Building & Construction 4 04-11-2010 11:10 PM
How do I Build Brick planters around patio itaska71 Building & Construction 3 03-31-2010 05:24 PM
Brick haze on brick over slab patio joeconroy Building & Construction 17 09-08-2008 01:44 PM
Brick up against sliding patio door with J Channel? sandyman720 Building & Construction 2 09-28-2007 08:47 AM
Steps on an umortated brick patio schott_robert Building & Construction 2 12-04-2006 08:15 AM
