How Often Should I Water The Lawn? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 09:09 PM   #1
Rewards Points: 154
how often should I water the lawn?
I reside in north east NJ 20 minutes away from NYC. The previous owners never watered the lawn before.
I am currently in the process of killing off the weeds in the back.
I am not sure on what type of grass it is. Some areas are kind of dried out.
Will post up some pics tomorrow morning.
Thanks.
llckll is offline   Reply With Quote
Old 06-18-2010, 09:10 PM   #2
I never water my lawn
Old 06-18-2010, 09:44 PM   #3
Do work
Rewards Points: 81
I don't either and its nice and green with some weeds.
liquidvw is offline   Reply With Quote
Old 06-18-2010, 10:41 PM   #4
Rewards Points: 154
So no need to water ever?
Old 06-18-2010, 10:46 PM   #5
I water if I reseed an area
I think I watered once a few years ago when we had a dry hot spell
But I felt like I was throwing an ice cube in the desert
I have landscaped & have been adding small trees to help shade areas
Once you start watering it seems the grass then needs the water
So if you stop...then the lawn suffers worse....IMO
I water my veggie gardens, but not the lawn
Old 06-19-2010, 12:03 AM   #6
Rewards Points: 410
Mow your grass high and your need for watering will greatly diminish.
I only water if the grass is under a lot of stress , once so far this year ( dry spring).
High Gear is offline   Reply With Quote
Old 06-19-2010, 08:06 AM   #7
Recomended for our area is an inch a week. Spring and early summer rains takes care of that. In the heat of the summer the grass will stress too much and go dormant or die. It's going to turn brown either way and reseading is a lot cheaper then $300 water bills.
Old 06-20-2010, 12:10 PM   #8
Rewards Points: 154
Should I fertilize the lawn as well? To try and revive and keep healthy? Or do it at the beginning and end of season? I plan on reseeding in September. Do it then?
Old 06-21-2010, 02:58 PM   #9
Rewards Points: 590
It seems like the only time a lawn really needs watering is when it doesn't rain... and then the drought restrictions go in effect, so you can't water your lawn!
When you reseed, you do have to water once or twice a day (unless it rains) until all the seed germinates.
operagost is offline   Reply With Quote
Old 06-21-2010, 03:01 PM   #10
Rewards Points: 154
How will you know when the seed germinates? You'll see it start to sprout?
Old 06-21-2010, 04:27 PM   #11
Rewards Points: 271
Shade trees, mowing high and watering less but longer are a good idea.
Frank Lardino
FrankL is offline   Reply With Quote
Old 06-21-2010, 04:30 PM   #12
Rewards Points: 154
Frank Lardino
Plan on doing the latter two.
Thanks.
Old 06-22-2010, 04:01 PM   #13
I didn't water my lawn about 4 summers ago and it turned brown, dusty and ugly. Since then, I've only watered during the summer every other day and was OK.
bobssurfin is offline   Reply With Quote
Old 06-22-2010, 06:55 PM   #14
Rewards Points: 154
Must have had high water bills.
Old 06-22-2010, 07:59 PM   #15
Don't know it all, yet!
three times a day
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 02:56 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Low Hot Water Pressure jifisher Plumbing 10 07-27-2009 07:48 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
