How Much Gravel/sand Under 20' X 20' Patio? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-07-2012, 12:09 PM   #1
How much gravel/sand under 20' x 20' patio?
How many inches of gravel should I put for a good base under a 20' x 20' patio? Topped with how many inches of sand? Do I need both gravel and sand? Patio will be made using 12" x 12" blocks. I live in Ct. Thanks.
chusav is offline   Reply With Quote
Old 09-07-2012, 04:54 PM   #2
Rewards Points: 3,370
This might answer your question.
  1. BASE PREPARATION
  2. We will prepare 4 inches of Class II Road Base for the vehicular areas and 2 inches for the pedestrian areas. Once the base has been set, we will hose the base down, and compact it until we reach a compaction level of 95%. At this point if the bob-cat drives over the prepared base, you will not see any tires mark, as it is literally hard as a rock, which is exactly what you want.
  3. SAND PREPARATION
    We will screed 1 inch of sharp angled bedding sand over the entire base, which is specially designed for the pavers. This is not round beach sand that you would find at your local beaches. It is sharp and angular in design and locks into the paver joints.
Canarywood1 is online now   Reply With Quote
Old 09-07-2012, 05:26 PM   #3
look up hpb (high performance bedding) or otherwise known as 1/4" chip. It's a little more pricing but works great for a diyer
RegLearning is offline   Reply With Quote
Old 09-07-2012, 07:01 PM   #4
Pay attention to the compacting portion of your instructions.
Evstarr is offline   Reply With Quote
Old 09-08-2012, 11:09 AM   #5
DIY-er
You need sand to have a smooth surface to set the pavers on. For a patio that will not support vehicles, you can use 4" of limestone screening as the base, make sure it is compacted with a tamper - you can rent one from a landscape supply store. You can also use aggregate or HPB as one other poster said. The reason they specify 1" of sand is that half or more of it falls through the aggregate base.
Kevin
www.home-additions-startup-guide.com
KevinPh is offline   Reply With Quote
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 08:41 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 10:53 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 02:41 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
