How To Level Pea Gravel & Lay Interlocking Tiles - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 10:04 AM   #1
How to Level Pea Gravel & Lay Interlocking Tiles
I have 400 sq ft of pea gravel in my yard underneath the playset and I bought these anti-fatigue interlocking tiles but I can't lay them flat on the pea gravel so do you have any ideas for what I could lay over the pea gravel to make the surface flat for the tiles or what is an easy way for me to level out the pea gravel to make the space as flat as possible so I can put these tiles down
Thanks.
fachabella00 is offline   Reply With Quote
Old 06-14-2010, 10:24 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the gravel can be smoothed or flattened with a simple screed such as a 2X4.
If the tiles are what I think they are, I think you will still have problems though as pea gravel tends to give a lot when you walk on it and that will likely cause the tiles you have to become disjointed from each other. You will probably need to remove most, if not all of the gravel so you have a stable base to lay the tiles on. I would suggest trying a few tiles together on various depths of gravel and walking on them to see if they come apart. Then keep removing gravel until you have enough support so the tiles stay assembled when walking, playing, and jumping on them.
Old 06-14-2010, 10:32 AM   #3
any suggestions for what I can put over the pea gravel to make it a flatter surface
Old 06-14-2010, 11:19 AM   #4
nap
You talking to me?
nap's Avatar
I don't understand what you mean. If you want the gravel flat, you use a screed to flatten it. I think you might mean to ask if there is something you can put over the gravel to make it more supportive and to that, the answer would be no. The problem is that as you step on the gravel, it will push out from under your foot unless you put some rigid board on top of it.
Think of it like going to the beach and walking in the sand. As you walk, the sand moves from under your foot and it sinks. If you put a blanket on the sand and then step on it, the sand still moves and your foot still sinks. If you put a board on the sand, only then will the sand not be pushed away.
so, there is really nothing I can suggest that would make the gravel more supportive. As such, removing it to a level where it does not move so much would be my only suggestion.
Old 06-15-2010, 04:07 PM   #5
You could add sand and like a processed road gravel to the pea stone. Compact and then level and lay tiles. You will need to lock up the pea stone or it will move under the tiles.
Bushman is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Drain Tiles, Gravel/ no Gravel? B Parker Building & Construction 20 07-16-2010 05:46 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 06:29 AM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
does the floor really need to be level before laying tiles? KUIPORNG Flooring 29 11-03-2006 11:56 PM
