How To Lay Stepping Stones In Area Wherw Grass Is Cut - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 09:58 PM   #1
How to lay stepping stones in area wherw grass is cut
I have a small area leading up to our cement patio and I would love to add about 5-6 stepping stones. How do I add them properly since this is also an area where I cut the grass?
dinosaur1 is offline   Reply With Quote
Old 06-18-2011, 11:09 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Dig out for them and inset them flush with the surface of the fill. You can mow right over them.
Was this a trick question?
XXX
Old 06-18-2011, 11:53 PM   #3
Nope, actually I'll post a pic of the area. Let me know how you would arrange them. In the pic you will see square stones around the patio in the mulch. I'm going to take those out and use those and add some more if needed. I was thinking about spacing them out a bit further like 2 ft apart...is that too far apart?
Old 06-19-2011, 12:22 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Stretch out a tape measure on the ground. Then walk normally beside it and note the average length of your stride. THAT is where you would place/space/center the stones.
Are you sure these aren't trick questions?
XXX
Old 06-19-2011, 12:25 AM   #5
something like this for example?
http://garden-photos-com.photoshelte...000NED7dM91FbI
Old 06-19-2011, 12:27 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yup something like that, okay I'm out of here.
XXX
Old 06-19-2011, 12:32 PM   #7
Gee thx...
Old 06-19-2011, 12:53 PM   #8
kwikfishron's Avatar
Rewards Points: 1,022
17-18” is a comfortable step for most humans.
Just lay them out on the ground and adjust until you’re comfortable with them, then brake out the shovel.
kwikfishron is online now   Reply With Quote
Old 06-19-2011, 12:59 PM   #9
Thx alot!
Old 06-19-2011, 01:54 PM   #10
Is it wise to pour some sand under the stones?
Old 06-20-2011, 06:29 AM   #11
You certainly can, the sand will make it easier to get a flat base. If I was just laying a few in my yard I don’t know that I’d go buy any sand though.
Old 06-20-2011, 07:10 AM   #12
I already have some.
Old 06-20-2011, 07:33 AM   #13
Pretending to be Retired
I used sand under the stones I set for a sidewalk to a garden area and it didn't work out that great. The sand allowed me to set the rocks easier, but they move some when I run the tractor over them. The rocks I set for hop scotch 3 years ago are still in the ground and still being used by my granddaughter.
BigD9 is offline   Reply With Quote
Swing set play area frame out... 68MHJCs Building & Construction 10 05-14-2013 12:32 PM
Outdoor Seating Area JackOfAllTrades Landscaping & Lawn Care 10 02-05-2010 02:01 PM
Keeping grass & weeds from growing in an area around my house? imola ghost Landscaping & Lawn Care 4 11-01-2008 07:11 AM
Easiest stones use to lay outside? KUIPORNG Landscaping & Lawn Care 6 06-27-2006 08:37 PM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
