08-06-2010, 03:16 PM
#1
How to improve soil under an existing lawn
Several spots in our 2-year old lawn are dying from lack of rain. It appears to be where more builder's sand than topsoil exists, such as where the septic tank and fields exist.
Is there a way to improve the soil, and moisture-retaining ability, shy of planting a new lawn?
Thank you.
08-06-2010, 06:55 PM
#2
DIY Hack
sure. you can rake a topsoil "dressing" right into the grass. it will look a little shady for a couple weeks, but if all you have there is dead lawn it might be an improvement. Don't go too heavy. Just rake it in so the grass is protruding out. do it in now, late fall, and again in spring if need be. if you have a good compost pile, add some of that
I have the opposite problem: a lot of clay in my soil. I rake in 7-10 big bales of peat moss into my lawn every spring. the drainage is getting a lot better, but it's a slow process for sure....
Those who can, do...
Those who can't criticize on the internet
The Following User Says Thank You to Mr Chips For This Useful Post:
08-06-2010, 09:17 PM
#3
gypsum a good soil additive use to improve the soils structure
08-06-2010, 10:38 PM
#4
DIY Hack
yea, i use gyp also, but there seems to be a lot of conflicting "experts" when it comes to gypsum. You can never go wrong adding organic matter like peat and compost IMO
08-07-2010, 04:41 AM
#5
paper hanger and painter
that and a little cow or horse crap
08-16-2010, 08:53 PM
#6
Don't know it all, yet!
My 2c worth-
The idea of raking in some topsoil dressing could have some use but could be expensive and labor intensive. I would core aerate first and hopefully some of the topsoil will find its way into the plug holes.
Gypsum has some benefit for loosening heavy clay soils in a limited area. Wholesale application as one might do with lime is generally useless.
It has been my experience that peat (and I use it routinely) is for moisture holding more than drainage. Perilite, coarse sand and, to some extent, vermiculite are for that purpose. Peat is very acidic. This should be considered when using it for crop that are pH sensitive.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
08-16-2010, 10:09 PM
#7
DIY Hack
Originally Posted by downunder
My 2c worth-
VERY cheap and VERY easy. you literally dump it and rake it
Not necisarily true, there is a lot of debate on this topic
Peat has great moisture holding properties, but it doesn't change the fact that its a great additive to help loosen packed clay over time
08-17-2010, 11:41 AM
#8
In order to both improve the soil under a lawn and not raise (the level of) the lawn, you must remove some of the not so good soil first.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
08-17-2010, 11:42 AM
#9
If you don't take away the clippings when you mow the lawn (chopping up, or mulching, the clippings is preferred) then the soil will enrich itself although the level of the lawn will be raised a tad.
08-17-2010, 10:23 PM
#10
DIY Hack
Maybe but it won't happen overnight. I've been raking in topsoil and peatmoss on my lawn every spring for the last 3 or 4 years, as well as mulching EVERYTIME i mow the law, and there is ZERO noticable differance in the overall height of my yard
08-17-2010, 11:15 PM
#11
Core aeration will open up the surface and provide an efficient space for whatever you want to apply. It has been used routinely several times a year on the better golf courses (except for a week after until the cores breakdown) and the following applications will go into the voids with some watering.
08-18-2010, 07:32 AM
#12
DIY Hack
Make sure you don't aerate during drought conditions, this can really stress a lawn
08-18-2010, 10:34 AM
#13
I've done a ton of research on this and one common approach has clearly emerged. But it does take a number of years. You don't need to remove anything...unless of course you want to go the route of ripping everything up...tilling in organics etc etc. But presuming you want to start from where you are.
First and foremost...BEST thing you can do (and for any lawn for that matter) is core aerate. With a compacted clay situation...do it spring and fall for AT LEAST 5 years...then maybe switch to just fall...forever.
Second, and do this right after core aeration...top dress. Not only does that provide much needed organic matter for the soil...it feeds the worms which end up doing a great deal of aerating through tunnelling and help via worm droppings.
The above two steps seem indisputable.
Beyond that...keep to a good fertilization program....and on that I'm going to switch mine to organic in the next year or so. Mulch every time you mow if possible to return nutrients in the clippings which will not at all raise the level of the lawn. Also mow high...I keep to 3" most of the year.... a bit lower at beginning and end of season...but never below 2.5". You can throw some gypsum and/or coarse sand down from time to time if you want but there's much debate on the efficacy of that. Beyond that all you need is patience. And yes top dressing can get a bit costly if you are paying someone to spread it. Good luck.
08-18-2010, 12:44 PM
#14
DIY Hack
I have clay soil, and have also done a lot of research and agree with everything in your post. I'd like to add that before you start adding sand, do your research. this is heavily debated ( as you mentioned) and many feel that if you use the wrong type of sand, you will do more harm than good. Also if cost is a concern, think twice about gypsum. It's pretty expensive, and it's not clear on how much it helps. Gypsum probably won't hurt at all, but IMO topdressing will do a lot more good, and pound for pound is a heck of a lot cheaper. I also mow at the highest setting and mulch the clippings, and when all my neighbors yards go brown when it's dry, mine stays a lot more green without any watering
08-18-2010, 08:19 PM
#15
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
