How To Figure Out How Much Rock To Order - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 09:36 AM   #1
how to figure out how much rock to order
Last fall I made a little pull off parking space off our paved driveway. I took some measurements and calculated what I thought would be the right amount of crusher run to use. I used a hand tamper (have more time than money) and figured I'd get the best result if I spread a pretty thin layer between each tamping. The result turned out fine with the stone solidly in place but I ran short. I was puzzled as I thought I had calculated everything right.
I think what happened is that I didn't take in account that a cubic yard of delivered crusher run (in a "fluffy" state) does not equal the same dimensions when compacted. Is my line of reasoning right or off base? I will be ordering more crusher run to finish the pull off and for various projects this summer and would like to do a better job at estimating. Is there any rule of thumb about the volume lost when compressed?
ChrisJJ is offline   Reply With Quote
Old 03-31-2011, 10:37 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,628
Ayuh,... Ordering stone isn't an Exact science...
The way ya did it is pretty much how it's done...
If ya think you might be short, just guesstimate how much extra ya need...
Old 06-02-2011, 07:46 PM   #3
Hi,
I was wondering the same thing. I calculate that I need 10 years of crusher run for my project. Should I get an extra 10%, or as much as 20% more? Any suggestions? I don't want to run short, but I don't want to end up with yards too much
Regards,
Bill
fabnavigator is offline   Reply With Quote
Old 06-03-2011, 07:10 AM   #4
Rewards Points: 1,668
Might try this site's calculator as it seems to account for density:
http://www.graniterock.com/how-to_th...n_calculators/
I've no idea if it works or what the appropriate density should be or what can be achieved with hand tamping and the material you are compacting.
bob22 is offline   Reply With Quote
Old 06-03-2011, 07:22 AM   #5
Civil Engineer
Rewards Points: 4,856
You are correct in assuming that a cubic yard delivered in the truck is a larger volume than the same material in place. Aggregate (sand, gravel, stone) ranges in density from loose to dense, depending on whether it has been compacted. The variation can be as much as 30 percent, meaning that 100 cubic feet of sand in the loosest condition may compact to as little as 70 cubic feet if you apply maximum compaction effort.
The actual amount of compaction you get depends on how loose the aggregate is to begin with, the type of compaction tool you use, the amount of time and effort you apply, and the moisture content of the aggregate during compaction. But this is all needlessly technical, a good rule of thumb is to buy 20 percent more than you need, you can always find something to do with a small amount of extra material if you don't use it all.
By the way, the 20 percent rule of thumb does not apply to peat moss and organic soil, which can be compacted far more than sand and gravel.
Daniel Holzman is online now   Reply With Quote
Old 06-03-2011, 07:56 AM   #6
Rewards Points: 120
Another factor, which can go either way, is that while you are measuring with a tape measure, your supplier is measuring with a loader bucket, and/or the box on the truck, and an inch or two higher or lower in the box, even on a "standard size" dump, can make a fair amount of difference. So, while a cubic yard has a defined size, by the time it gets to you, as Bondo says, it is not an exact science.
Old 06-03-2011, 10:10 PM   #7
Thank you for your help.
My calculations say I need 10.25 yards. I'm going to assume that when I put down 2 inches, I'll end up with 1.5 inches after compaction. That means that I need 13.6 yards. I'll round that up to 14 yards. I'll probably have way too much, but that is the lesser evil.
I think I'll pay an extra delivery charge, and have it brought in two 7 yard loads. I don't want to damage my asphalt driveway.
I'm going to do this next weekend. I'll post the results.
Old 06-18-2011, 06:40 AM   #8
I completed the base installation last weekend.
I'm glad I ordered all 14 yards. I probably had about a yard extra, but I wouldn't have wanted to try and use every last bit. I used a skid loader to move the gravel from the pile to my walkway, and since I didn't want to scrape the bucket on my driveway, I had to leave a thin layer behind.
The gravel came in two loads, from two different places. One had a good moisture content, the other was dry. It took a fair deal of extra work to add enough moisture to the dry gravel in order to get good compaction.
I got from 3/8" to 1/2" of compaction out of a 2" spread layer of gravel.
There was no problen with driving the truck (with 10.5 tons of gravel per load) over my asphalt driveway.
Ideal order of doing improvements zurich78 General DIY Discussions 7 03-07-2011 06:30 AM
order of install after demo? Burton8012 Remodeling 3 02-18-2011 01:40 PM
Tips for landscaping trees on solid rock!!! Cindyhello03 Landscaping & Lawn Care 4 06-15-2010 07:01 PM
Getting rid of river rock Shadoglare Landscaping & Lawn Care 9 06-14-2010 10:51 AM
How to calculate how much rock fill and asphalt to order? Negativecreep0 Landscaping & Lawn Care 5 04-08-2010 09:08 PM
