How Far To Dig Under Drainage Pipe? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 10:44 PM   #1
Rewards Points: 373
How far to dig under drainage pipe?
This is related to my other post, but specific to a drainage pipe.
There is currently a plastic corrigated pipe dug in the ground. Originally there were rocks around it, but over time dirt has accumulated around it. So I am digging it out and putting a small trench to divert water to it.
I was thinking of digging about 6 inches below the opening so the dirt will not accumulate as quickly, and lay rocks around it.
In a few years (hopefully many), I would have to dig it back out again if the dirt accumulates too high and starts to get close to the drain.
I think this is a better alternative than laying the pipe in the ground and covering it since I will not be able to see if its backing up, and it will be more work to dig it back out.
The backyard has a lot of clay, so this has been a big problem. With the extra depth, a few inches of water may sit there, but I think it is better than having it back up. I was going to plastic line the area so the water will not seep in the ground.
How far to dig under drainage pipe?-drain1.jpg   How far to dig under drainage pipe?-drain2.jpg
greentrees is offline   Reply With Quote
Old 05-27-2012, 06:23 AM   #2
biggles's Avatar
check this YOUTUBE out.... http://www.youtube.com/watch?v=1UfIg...eature=related
Drainage Pipe w Sock..no rock??? SuzyHomeMaker Landscaping & Lawn Care 7 05-15-2012 09:12 AM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 12:05 AM
