How To Drain A Backflow Preventer When Winterizing Sprinklers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-05-2009, 11:30 AM   #1
Just call me Andrew
Rewards Points: 1,020
How to drain a backflow preventer when winterizing sprinklers
I am preparing to do a winter blow-out for my sprinkler system. I had a plumber install a Watts 007 Double check valve assembly, it is located outside the house.
I have a blow-out/drain port downstream from the backflow preventer (outside), as well as before the DCVA (inside)
I have read that it is bad for the Doublecheck valve to blow air through it, and that the air compressor should be hooked up after it (so, outside in my case).
I have already cut off the water source to the sprinklers and drained the inside piping. After I do the blow-out, how do I go about draining the water from the 007 itself?
Thanks.
secutanudu is offline   Reply With Quote
Old 10-05-2009, 09:57 PM   #2
Rewards Points: 152
I think they frown on blowing through the DCVA's because it's hard on the check valves. So, you could pop the top (4 1/2" bolts IIRC), remove the check valve assemblies and blow away
burnt03 is offline   Reply With Quote
Backflow Preventer - M2 or M3? velcrobots HVAC 6 10-04-2009 12:20 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
