Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-12-2007, 09:57 PM   #1
How do I seal the bottom of this fountain (pics)
I have a fountain similar to this one. I paved an area with stepping stones and would like to put a fountain in the middle. The bottom circle comes in sections. I'm not sure how to seal it
weatheredwood is offline   Reply With Quote
Old 08-12-2007, 10:55 PM   #2
Agent 000
SecretSquirrel's Avatar
What is this fountain made of? It looks to be marble. If it is some form of masonry then here's what I would do;
I would parge it with Thoroseal . After curing I would coat it with some acrylic elastomeric masonry coating, but that is optional and perhaps overkill. The coating can be color coordinated (tinted) to suit your taste.
Last edited by SecretSquirrel; 08-12-2007 at 11:16 PM. Reason: Edited original advice
SecretSquirrel is offline   Reply With Quote
Old 08-13-2007, 07:04 PM   #3
It is made of cement. I would have to seal the bottom (stepping stones) and around the inner circle. What is this stuff like? Is it permanent? I don't know if it will ever have to be moved in the future.
Old 08-13-2007, 07:36 PM   #4
Agent 000
Maybe I'm a little confused. If this is a fountain then why isn't it already sealed for water containment? So if I have this correct, you've set stepping stones in an area and you're going to place the fountain on top of the stones. Are you just asking how to seal the sections that make the surround or are we building some type of water containment? Help me out with a little additional information if you can.
And yes the Thoroseal is permanent... very permanent.
Old 08-13-2007, 10:18 PM   #5
Everything is pretty much sealed except the bottom. It is made up of around 8 pieces. You just place them together. I don't know how to seal the seams and bottom to retain the water in the bottom portion. I am using stepping stones like tiles in a small garden area.
Old 08-14-2007, 07:46 AM   #6
Agent 000
Ok, I did a search on this fountain and got this snippet;
The Toscana Pool Fountains combine our largest and most popular fountains with the magnificent nine-foot diameter Toscana Pool. The Toscana Pool is a unique hybrid ground pool that combines classic, easy-fit cast stone surround walls with a premium, one-piece fiberglass bowl. Since the fiberglass bowls are color cast in several shades complementary to our Henri finishes, the Toscana Pool Fountains are available in only selected finishes.
Sooooo, do you have this one piece fiberglass bowl?
Old 08-15-2007, 05:57 PM   #7
Agent 000
So what's the verdict? Inquiring minds want to know.
Old 08-21-2007, 04:33 PM   #8
Bad Karma's Avatar
This would seem like an important piece.
Bad Karma is offline   Reply With Quote
Old 08-21-2007, 07:15 PM   #9
Agent 000
Ya think? LOL
They had me scratching my head on this one.
Old 08-21-2007, 09:57 PM   #10
Sorry about the delay. I didn't actually purchase the fountain in the picture. It just looks similar to that one. I didn't get a fiberglass bowl with mine. I don't know if that is how they are commonly sealed.
Old 08-31-2007, 03:38 PM   #11
What's a "Tool?"
Correct me if I'm wrong, but do you just want to seal the vertical spaces in between the base sections?
If so, I'd just go with a silicone caulk - it's inexpensive, aesthetic, waterproof, and won't prevent you from taking it apart and moving it in the future.
AZJD is offline   Reply With Quote
Seal Cat Smell On Brick flyingzs Flooring 5 08-09-2007 02:20 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Induction blower seal ktritz HVAC 4 03-05-2007 09:52 PM
Piece on bottom of toilet tank won't seal Squeeealer Plumbing 1 07-14-2005 09:13 PM
