Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 04-26-2012, 02:08 PM   #1
How do i prepare wood post for fence
I am putting a 5/4 x 6 x 8 rail fence in my yard. I will probably buy pt wood at home center. Many times wood is "wet". Should i allow posts and rails to dry more before installing? question two: should i prepare the buried portion of the posts with tar? thanks for help.
EFTHIM is offline   Reply With Quote
Old 04-26-2012, 02:32 PM   #2
When I put in my fence I just used pressure treated posts and they lasted about 20 years before they rotted out and our soil is mostly clay. It doesn't matter if they are wet or dry when you put them in but put some stones in the hole before you plant the post for drainage. I didn't concrete them in since they were just for "pretty", but I've had another PT post concreted in my back yard for 17 years and it's showing no sign of rotting so far.
Tomboy123 is offline   Reply With Quote
Old 04-26-2012, 02:41 PM   #3
cortell's Avatar
I wouldn't worry about letting them dry out. Typically, such precautions are used to mitigate the effects of shrinkage. In a fence application, shrinkage is hardly a concern. In applications with lower tolerances, yes.
As for tar on the post, I've heard of people doing that. I don't bother. I take three measures to avoid post rot:
1. pour several inches of pea gravel at the base of the footing
2. use sonotube and cut it to four inches above grade (six if you're extra cautious, but it becomes a bigger eye sore the higher you go)
3. shape the top of the concrete footing in a dome shape to prevent water pooling
With these precautions, I have enough faith in the PT lumber...at least for a fence post. As for tar, I've always wondered what happens when moisture at the base spreads to the buried part of the post. Does it then get trapped by the tar as it tries to dry outwards? Sounds like a possibility to me. Thus I avoid it.
cortell is offline   Reply With Quote
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 09:04 PM
Wood Patio Cover Post Grounding Madracki Electrical 10 07-04-2009 03:49 PM
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 05:54 PM
