How Do I Prepare Ground For Framed Shed? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 01:12 PM   #1
How do I prepare ground for framed shed?
My back yard is Florida dirt/sand with oak saplings sprouting everywhere. I want to put up a shed, but I'm worried about the saplings popping through the floorboards later on. What's the best way to remove them, or kill them off before I lay a crushed rock foundation?
Claybird is offline   Reply With Quote
Old 05-12-2012, 01:18 PM   #2
Rewards Points: 13,458
No idea on how big they are. If there big enough I pull them out with a chain so roots and all come out.
Use a matox to cut the roots.
Spray the area with total vegitation killer.
Old 05-12-2012, 01:33 PM   #3
Rewards Points: 3,528
I hope your not going to build that shed on top of the crushed rock,at least put it on deck blocks.
Canarywood1 is offline   Reply With Quote
Old 05-12-2012, 01:36 PM   #4
The siding on a shed should be no closer then 8" of the grade. Any closer and it's going to rot.
Old 05-12-2012, 01:54 PM   #5
No problem on the build
I grew up building with masonry, framing, roofing, so I'm good with all the building. I was just concerned with the ground prep. It will be sitting on deck blocks. The saplings are very small, but heavily rooted.
Old 05-12-2012, 05:47 PM   #6
The deck blocks are 8 inches high,so take care of the saplings and you're good to go.
Old 05-13-2012, 09:47 AM   #7
Rewards Points: 236
Originally Posted by joecaption View Post
matox
http://www.google.com/search?q=matox...Hof28gTx2YnhCA
Fix'n it is offline   Reply With Quote
Old 05-13-2012, 11:54 AM   #8
Im going to remove what I can and use the vegetation killer. I don't know what a matox is though.
Old 07-10-2012, 02:45 PM   #9
Stumbled on this thread... thought I'd put in my two cents if anyone else is interested:
Oaks are not weeds--they are slow-growing. Just rip them out and put the shed on top.
Don't worry about plants growing through the floorboards, as plants will not grow without sunlight.
Personally, I'd dig up the oaks and put them somewhere else in the yard. Oak trees are fantastic, valuable, and these are likely native (so there's no extra maintenance required--ever).
Biologist is offline   Reply With Quote
Old 07-10-2012, 05:40 PM   #10
Too Short? Cut it Again!
I would relocate them if you have room also. Or someone may want them if you can dig them out.
If not, cut them off as close to the ground as possible. Paint---not spray---a vegetation or stump killer or something like Roundup on the cut.
Old 07-12-2012, 11:48 PM   #11
Originally Posted by Fix'n it View Post
maddox?
dariusld is offline   Reply With Quote
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Multiple Ground Rods, help Ralph III Electrical 72 02-14-2012 09:31 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
