How Do I Plan Out A French Drain? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 10:23 PM   #1
I ask the impossible!
Rewards Points: 660
How do I plan out a french drain?
I'm attaching a diagram below not necessarily to scale, but showing the area I want to put a french drain for dispersing drainage from a sump I plan to put in the crawl space for a foundation drainage system for my spread footings. The front yard has an area probably around 15' x 15' shown, it slopes to the street and is free of underground utilities, but probably not free of roots from the tree shown. The driveway is going to be replaced, probably in the fall or next year with concrete, but within a week it will be torn out to replace a main sewer pipe under the driveway, and gravel driveway will temporarily be installed.
Should I keep the system a particular distance from its concrete borders, the driveway, sidewalk, walkway? Is 1 straight pipe of whatever length possibly enough, or should I do more than that?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
French Drain Help Please moze Landscaping & Lawn Care 19 02-16-2011 11:09 AM
Vinyl pool floating after french drain installed jeanniet1972 General DIY Discussions 2 10-13-2010 09:39 AM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 10:55 AM
Do I need to waterproof my basement if I already have a french drain? buratti Building & Construction 4 03-20-2010 03:32 PM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 09:37 AM
