How Do I Make A Form For Cement Gas Firepit - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 12:25 AM   #1
how do I make a form for cement gas firepit
I just want a simple round firepit but cant figure out how to make a form for cement
cverdi2 is offline   Reply With Quote
Old 02-16-2011, 12:30 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Use retaining wall blocks. They make them for making circles. I've used one/them for years in my yard.
XXX
Old 02-16-2011, 10:40 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,.. Concrete is Not the best thing for having a fire in,...
It'll spald, 'n possible Blow chunks at you as it gets extremely Hot...
Old 02-16-2011, 10:54 AM   #4
Experienced
Jackofall1's Avatar
Welcome cverdi2, to the best DIY'r site on the web.
I have to agree with both the gentlemen who offered the first 2 comments. You could get some fire brick, as opposed to landscaping block, but concrete is a no no.
Mark
Old 02-16-2011, 11:44 AM   #5
Concrete & Masonry
Rewards Points: 530
Not sure exactly what you have in mind for the design, but here's 2 pics of one we did inside of a patio last year:
Ditto on using firebrick as well, as concrete is not the proper substrate to have that close to a fire. If on a tighter budget, steel rings work as well.
jomama45 is offline   Reply With Quote
Old 02-16-2011, 12:18 PM   #6
I will be placing a fire bowl inside the pit
wont that be okay, was going to use a burner ring and fill it with the crushed glass, just trying to come up with a round decorative form to hold it?
Old 02-16-2011, 06:39 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Cement retaining wall blocks are not the best type of block to use for a fire ring but they last a considerable time and are easily replaceable. It just depends on how serious a guy is about having a fire ring. Gas fire rings don't put off that much heat anyway.
Mine has several cracked blocks from the heat but is only eight years old. Adds to the character.
XXX
Old 02-16-2011, 07:06 PM   #8
Bondo's Avatar
Rewards Points: 650
Ayuh,... I've got several firepits at different properties,...
1 is an old dayton truck wheel, with a piece cut outa the side,... 24" diameter...
It just sits on the shoreline rocks at the Lodge in Maine...
1 is an 18" section of a 36" diameter propane tank...
It sits on loosely set old chimmey bricks, on top of the concrete patio, shore-side on the Chaumont river...
The bricks break up over time, but protect the concrete below 'em...
The 1 in the backyard is a piece of 48" hi-way steel culvert, about 2' tall...
It just sits on the ground...
Old 02-16-2011, 09:01 PM   #9
After looking at Jomama's pics I'm almost embarrassed to post these.
This is the project I started last year and hope to finish this summer.
I needed a retaining wall to raise the backyard to level to the garage.
I was able to get the granite slabs and old used cobblestones for cheap. My wife and I furnished the labor. I wanted to incorporate a firepit/cooking center and had the same problem as you have my simple solution was to cut and nail eight equal length pieces of 2 + 4 cut at 22.5 degrees on my mitre saw which gave me an octagon to use as a form. I poured my pad and laid my stone in a circle. the edges of the pad will not even be visible when I'm done. I did this because I couldn't figure out how to make a circle.
Here are a few pics, one is the pad, another is the pit and the third is a grill I had welded to build the fire on.
My intention is to have the pit waist high on the low side of the wall while it's in the ground when I fill the backside of the wall.
how do I make a form for cement gas firepit-003-small-.jpg   how do I make a form for cement gas firepit-010-small-.jpg   how do I make a form for cement gas firepit-029-small-.jpg
The Hammer is offline   Reply With Quote
How would I form this sump pit design? walkman Building & Construction 8 05-03-2010 02:47 PM
NG Firepit Problem jonzey General DIY Discussions 2 06-16-2009 12:17 PM
Can a septic line make right angles? Randell Tarin Plumbing 7 01-26-2008 09:01 PM
Do they make this? Malcolm Roofing/Siding 3 10-14-2007 12:23 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
