Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-22-2009, 07:41 PM   #1
Default How do I get rid of Plantain weeds?
My yard is full of them and I've been plucking them out for days now. Some areas that were plucked clean are starting to grow more Plantain again.
Besides plucking them, is there another way of getting rid of them without hurting my grass? Some kind of spray, chemical, etc?
hayzen is offline   Reply With Quote
Old 08-23-2009, 10:09 AM   #2
ccarlisle's Avatar
2,4D or Killex.
ccarlisle is offline   Reply With Quote
Old 08-24-2009, 03:06 AM   #3
Thanks, I'll give that a try.
Old 08-24-2009, 09:18 AM   #4
Any broad leaf herbicide for lawns will work... which is common practice but your adding chemicals to a lawn is unsafe for humans, the inviorment and animals... as recent studies show.
Puttling the weeds out is the only natural way I can think of.. and then eliminate the weeds comming back again...
After you get rid of the weeds, make sure your lawn in healthy by mowing at 3.5 inches high which makes it harder for seed germination.
Apply corn gluten in the spring as a pre-emergent and you can use it in the fall.
Apply lime which will enable your plants to better utilize the nutrients that are in your soil..
Mow higher right before a drought
Lots of natural things you can do to discourage weeds from germinating in your lawn!
chrissygarden is offline   Reply With Quote
Old 08-24-2009, 09:34 AM   #5
Extreme DIY Homeowner
Scuba_Dave's Avatar
I do a lot of weeding byhand when I'm outside with my son
The front I have used Scotts program for years - very few weeds
Due to construction one side & the back suffered from my truck/backhoe being driven across
I'm hoping to start getting them back in shape next year
I also had a grub problem out front
I didn't know until a skunk dug up a 6x12 area
Now I use grubbex, but maybe changing to milky spores (?) after talking to a neighbor
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 08-25-2009, 08:26 PM   #6
Old fart still learning!
Would this not depend on the present pH and the pH requirements of the crop, i.e. lawn?
What, me worry?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 08-27-2009, 07:14 AM   #7
The only way to get rid of plantains is to dig them up, getting all of the root out. Pieces of root can regenerate, and the plantains can return. Water the area well a day in advance of when you plan to weed, then use a flat screwdriver or dandelion digger to dig the plantain out. Use the tool to loosen the soil around the taproot. Once the root seems free, pull the entire plant out.This will prevent the plantain from spreading its seed all over your garden.
lilypotter is offline   Reply With Quote
Old 11-08-2009, 07:04 AM   #8
Good one 'lilypotter'! Dig 'em up! It's the only way to fly!
Lali is offline   Reply With Quote
More On This Topic
Crabgrass is considered to be a weed. It spreads quickly and thrives in both high temperatures and dry weather conditions. It's unrealistic to expect your lawn to be free of crabgrass, but there are some ways to minimize it and prevent future growth. One... Read More »
I'm Doug Smiddy of Smiddy's Gardening Services here on behalf of expertvillage.com and welcome to my garden. Today we're here to talk about low maintenance gardening. Okay, now here's a subject that we don't really like to talk about or even think about... Read More »
How to Use a Weed Eater
How to Use a Weed Eater by Expert Village
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about the proper use and maintenance of a yard weed eater. For the most part, everyone's yard in the neighborhood has pretty much... Read More »
Canada thistle (Cirsium arvense) is a broadleaf perennial weed that can wreck havoc in turfgrass. In many states it is considered to be a threat to agricultural lands. It goes by many name: creeping thistle, California thistle, corn thistle or field... Read More »
You may not know the name of this weed, but there's a good chance your lawn has it. Purslane is a summer annual weed that is common throughout the world. But to eliminate a weed from the lawn, you first have to identify the culprit. Here's a mug shot of... Read More »
Yard Advice Please - Lots of Weeds! Myrkur Landscaping & Lawn Care 7 06-15-2009 11:41 PM
Tilling - w/ Weeds dankreboot Landscaping & Lawn Care 8 04-06-2009 08:16 PM
Weeds are taking over...help jstcruzin Landscaping & Lawn Care 29 11-05-2008 09:06 PM
block paved patio weeds Tim Watson Landscaping & Lawn Care 3 08-18-2008 07:59 PM
Basic lawn care help, WEEDs SuperAkuma Landscaping & Lawn Care 5 07-31-2008 08:58 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
