How Do I Fix My Sprinkler? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 07:58 PM   #1
I love my new front yard!
Telfair's Avatar
Rewards Points: 158
How do I fix my sprinkler?
I was walking around my home today when I noticed the inside of my sprinkler seems to of shot out under water pressure?!?!?!
I tried to put it back it place, but it seems to just sit there, how do I lock it down?
I tried to twist it but it don't seem to...?
So I turned off the sprinklers for tomorrow morning in hopes to get this fixed by tomorrow?
Please help me, I sure hope I dont have to tear up my lawn to replace the whole unit..?
Thanks.
Telfair is offline   Reply With Quote
Old 02-05-2012, 08:50 AM   #2
You actually may get lucky and be able to unscrew it and simply screw a new one in. If that doesn't happen, screw the old one back in to keep dirt from getting in the water line, then dig out around it, like 3 inches on each side is all you need. Whenever I dug them out, I would start to unscrew it then reach my fingers underneath it and push the dirt down a little so that hopefully the water line stays clear. Install your new head, and worst case scenario if you did get dirt in the water you will just have to take the top and the filter of/out of the head and turn it on for a second to clear the line...
My humble Man Blog
jasonreck71 is offline   Reply With Quote
Old 02-05-2012, 08:59 AM   #3
Moves some the rocks back by hand, pretty sure you will get lucky and just be able to screw a new one in...
My humble Man Blog
Old 02-05-2012, 03:54 PM   #4
Telfair's Avatar
Rewards Points: 158
Thanks guys Don't know why I didn't think about how I can just unscrew it & screw another one back in its place..
I have plenty of spares..
& actually the lines run under the grass not the red lava rocks.
I replaced it today & it should be fine.
Strange how this thing broke..?
I thought it unscrewed itself under water pressure or something but as you can see the plastic actually broke?
Must of been cracked before putting it in & was only a matter of time?
Old 02-05-2012, 04:03 PM   #5
piece of cake, glad it's working good for you now
My humble Man Blog
Old 02-07-2012, 08:51 AM   #6
That is a pretty normal spot for the head to break. Most of the time it happens when blowing the system out for the winter but can happen when it snaps up due to high water pressure.
mkgoetz is offline   Reply With Quote
Old 02-07-2012, 10:13 AM   #7
Telfair's Avatar
Rewards Points: 158
Funny thing is I don't really have high water pressure.
& the winters here in SoCal are very mild.
Old 02-07-2012, 11:03 AM   #8
On the edge of the grass on rocks like that I bet the mower wheel hits it once and a while and that was probably enough, but some times you just get a dud
My humble Man Blog
Old 02-07-2012, 12:17 PM   #9
Telfair's Avatar
Rewards Points: 158
They're in the lawn pretty deep, but you might have a point, I'll be more careful.
Locating underground lawn sprinkler pipes Thurman Electrical 8 06-30-2014 07:33 PM
Assistance on Toro sprinkler system Dgreaney Landscaping & Lawn Care 5 06-12-2011 08:38 PM
Home's Pressure valvue and sprinkler steve0617 Landscaping & Lawn Care 2 01-04-2011 01:37 PM
Pond aerator and Sprinkler system hd82 Landscaping & Lawn Care 0 07-31-2010 07:46 PM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 06:39 PM
