How Do I Figure Out What Lives Under My Lawn? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 11:10 AM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
How do I figure out what lives under my lawn?
There's a hole about 2" in diameter on my lawn about 2' from the flower bed. inside the flowerbed there is another one - I had honestly forgot about it since I obviously don't spend much time on the lawn these days.
The other day I found hole #3 - this one is right next to one of the piers of my deck - now I'm mad!
I initially thought "moles" but then realized there's no dirt "hill" on the lawn next to the holes, literally just the hole with nothing around it.
What can make holes like this? And ........ where does the dirt go??????????
CoconutPete is offline   Reply With Quote
Old 11-28-2011, 01:25 PM   #2
Rewards Points: 148
In my neck of the woods, that would most likely be a chipmunk, otherwise known as a ground squirrel in some parts. They always seem to have one hole that is more concealed, and one in the open for when they need a quick place to get to while frolicking around the yard.
Old 11-28-2011, 01:37 PM   #3
Too Short? Cut it Again!
Groundhogs might be around in your part of the World. I once found a family living high under a garage. French wine, custom furniture, hookers, cable tv, stereo and cigars in a living space hollowed out almost the entire dimensions of the space. Little holes for ingress/egress like you describe outside.
They had been at it so long we had to demolish the garage floor, fill in the cavity, and start over. I have no idea where the dirt went as they made their home.
Old 11-28-2011, 01:51 PM   #4
Rewards Points: 148
Sdsester, those groundhogs must have been spending everything they had on wine, cigars, and other vices, and nothing on food. Our groundhogs would never fit down a 2" hole.
Old 11-28-2011, 06:19 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
Like amphetamines
I don't think there would be ANY groundhog fitting down a 2 in hole.
Old 11-28-2011, 06:30 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,.... 'round here, Chipmunks live in the 2" holes in the ground, 'n Woodchucks live in holes 'bout 6" across...
Either way,...
Dump a container of D-con rat pellets down the hole,...
It usually get's rid of 'em...
Old 11-29-2011, 09:55 AM   #7
Rewards Points: 504
This is in CT, not Denmark - but it seems everyone figured that out already.
Well, I do see chipmunks very often zip across the yard. So these things like to dig too huh?
Do mole traps work for these things or should I try the mothball or bubblegum method?
Old 11-30-2011, 08:54 AM   #8
Bondo's Avatar
Ayuh,... I kinda doubt the mole traps'll work,...
as for the mothballs or bubblegum,..??
Are ya trying to piss 'em off, or kill 'em,..??
Like I said before, D-con rat pellets dumped down their holes will take care of the Problem...
Old 11-30-2011, 09:55 AM   #9
Rewards Points: 504
D-con rat pellets .. got it. Doing it this weekend.
To answer your question - I'm trying to kill'em
Old 11-30-2011, 11:45 AM   #10
Rewards Points: 148
Pellet gun or .22; very sporting at a distance.
Old 11-30-2011, 04:13 PM   #11
chrisn's Avatar
Rewards Points: 612
shotgun works wonders
maybe not as sporting as a .22 but it will do the job
Old 11-30-2011, 05:21 PM   #12
Rewards Points: 148
I suppose; certainly nothing to bury or toss in the swamp that way.
Old 12-05-2011, 08:27 AM   #13
Rewards Points: 504
I live in the center of town, not sure what you can really pull off there as far as "things that make projectiles fly". Anyways.. I got the goods, will report back with my findings.
Old 12-05-2011, 08:35 AM   #14
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
.........skunks......
they're going after the grubs that are living under your lawn.........
tcleve4911 is offline   Reply With Quote
Old 12-05-2011, 04:56 PM   #15
chrisn's Avatar
Rewards Points: 612
There's a hole about 2" in diameter ( from the OP)
That would make it a vey, very small skunk
What the hell happened to my lawn? (also: reseeding when weeds are present. N.Y.) Deck Landscaping & Lawn Care 14 05-24-2011 12:45 PM
Lawn Help garydigital Landscaping & Lawn Care 4 03-06-2011 03:36 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 12:34 PM
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 08:38 AM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 11:36 AM
