How To Cut Retaining Wall Block - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-10-2012, 11:12 AM   #1
jkk
Rewards Points: 233
How to cut retaining wall block
Can these blocks be 'cut' in half by hitting with hammer?
If I need to custom cut these to something other than in half, what are my options? I think we only have to cut about 20, max.
thanks.
jkk is offline   Reply With Quote
Old 11-10-2012, 11:21 AM   #2
Rewards Points: 13,270
I use a brick chisle and score a line on both sides, keep hitting it and the block will split right along the line.
Old 11-10-2012, 11:24 AM   #3
DIY staff
Rewards Points: 7,174
Hammer and cold chisel----make a series of notches then smack it hard along the score line----
Rented or borrowed wet saw------
Angle grinder with a diamond clipper blade-------
Old 11-10-2012, 11:37 AM   #4
jkk
Rewards Points: 233
Thanks,
I have a 4" angle grinder with a tile cutting blade. I guess I could use that and some water for the cuts?
Old 11-10-2012, 11:50 AM   #5
DIY staff
Sure you can-----those blocks are soft----cutting goes quick-----
Old 11-10-2012, 01:40 PM   #6
Too Short? Cut it Again!
I should actually think for those blocks, a standard $3 masonry blade or two and your angle grinder would do without wetting them. They are not hard. Diamond might be overkill in this instance?
If you do decide to use a power tool with water? Please make sure you have a GCFI protecting you?
Old 11-16-2012, 01:10 PM   #7
jkk
Rewards Points: 233
I have an Hitachi G12SR3 grinder, 4.5". I bought a cheapy Skil blade but the spindle hole is a bit larger than the spindle, and the blade is not centered.
Aren't these spindle hole sizes standardized ?
Old 11-16-2012, 01:36 PM   #8
Civil Engineer
Rewards Points: 4,566
You can certainly use an angle grinder. When I had to cut a number of concrete retaining wall blocks, I used a diamond blade in my circular saw. Blade cost about $10, cut really nicely. I scored it about 1/4 through both sides, then whacked it with a hammer and it broke clean. Just make sure you use a NIOSH rated mask when cutting concrete, the dust is very bad for your lungs.
Daniel Holzman is online now   Reply With Quote
Old 11-16-2012, 03:30 PM   #9
Rewards Points: 127
They are, but there is more than one size. You likely have a 5/8" arbor with a 3/4" or 7/8" spindle hole.
ptarmigan61 is offline   Reply With Quote
Old 11-18-2012, 11:52 AM   #10
jkk
Rewards Points: 233
I was able to cut the blocks with a chisel. Now I have to cut the top caps, will probably need a blade since these are asthetic elements.
Old 11-18-2012, 12:17 PM   #11
You are definitely going to want some kind of circular blade saw for the caps, as you are going to want them to fit perfectly flush. Splitting the blocks (with the chisel) doesn't give a nice smooth side, as you have seen I am sure. For my wall, I split the blocks on the ends for the aesthetic appeal, but cut the caps with a circular blade. I know some people rent bgas cut off saws, I bought a 7.5 inch skil electric circular saw for 50 bucks and a mansonry blade for about 10. The circular saw's standard wood blade has come in handy for lots of projects since. It also beats renting because you are not rushing everything into one day, IMO.
teamcampreder is offline   Reply With Quote
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 05:45 PM
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 09:39 PM
retaining wall around chimney stack Master Brian Building & Construction 0 08-25-2010 04:27 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
