Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-26-2010, 12:39 PM   #1
How to change shredder blade?
Not sure if this is the right forum, but let's give it a shot. I have a Stihl leaf blower, and the shredder blade needs changing. I have a new blade, but it is not readily apparent how to change it. I'm grabbing the blade with a Vise-Grip and trying to turn the nut with a rachet, but I can't get it to go. Does anyone know how I should be trying to do this? Thanks much.
mntentman is offline   Reply With Quote
Old 10-27-2010, 08:42 AM   #2
It is possible that you need to turn it clockwise to remove instead of counterclockwise. Only a guess if it doesn't budge turning it cw. Have you tried any liquid wrench on it first?
bob22 is offline   Reply With Quote
Old 10-27-2010, 08:49 AM   #3
I emailed Stihl about this yesterday. The response was that it is very difficult to do, you really need to put the blade in a vise and use a breaker bar, and is not a common procedure... yet the only way to change the blade. LOL. I guess they expect you to buy a new one whenever the blade goes bad.
I think I may try filing the edge of the blade to make it sharper, at least that way it might chop up the leaves.
Old 10-30-2010, 08:46 PM   #4
I had one once and had the same problem.
Oops! is offline   Reply With Quote
Old 10-30-2010, 09:07 PM   #5
Don't know it all, yet!
mntentman,
Did Stihl tell you if it is a RH or LH thread? Do you have access to an impact wrench? Much easier that way because you don't have to try to hold so tight against it- the impact absorbs the torque.
For example, I usually don't even have to hold my mower blades when removing them for sharpening.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 10-31-2010, 09:31 PM   #6
Downunder... no, they didn't, but I'm sure I could find that out. I can get access to an impact wrench, I may give that a shot.
To Oops! .. so what did you end up doing?
Thanks, all.
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 05:26 PM
Removing a blade from an old Craftsman Circular Saw Davem720 Tools 1 07-05-2010 10:17 PM
IKEA Cabinets and a good saw blade (my experience) DIYatHome Kitchen & Bath Remodeling 0 12-13-2009 08:32 PM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 09:08 PM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
