How To Calculate How Much Rock Fill And Asphalt To Order? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 09:29 AM   #1
How to calculate how much rock fill and asphalt to order?
Hey guys I have a large mud pit in the middle of my Scrap Yard that I want to fill in with 1.5" stone and then do a layer of blacktop over that
how can I calculate how much (in tons) of stone and blacktop I need to fill this area
the area is 50 ft x 75 ft, and I have been told I should do a minimum of 8" of rock fill............. thanks
Negativecreep0 is offline   Reply With Quote
Old 04-08-2010, 10:11 AM   #2
the quarry can give you cubic yrd to tonnage for type of stone you choose
The older I get the better I was
Old 04-08-2010, 07:33 PM   #3
GardenConcepts's Avatar
Rewards Points: 150
length x width x height/27 = cubic yards. Cubic yards x 1.25 will give you the approximate tons of gravel. Different types of stone have different weights, so this will vary. 50 x 75 x .66 = 2475/27 = 91.6 cubic yards x 1.25 = 114.58 tons.
I don't know what asphalt weighs, but you can calculate cubic yards the same way and call a quarry that makes asphalt. Typical asphalt is 2" base coat and 2" topcoat. Of course, you could go thicker for heavy equipment.
GardenConcepts is offline   Reply With Quote
Old 04-08-2010, 07:38 PM   #4
Rewards Points: 1,574
See:
http://www.weldonmat.com/calculators.htm
about halfway down page.
I put your dimensions in and it came back with 131 tons. Seems like a lot to me.
bob22 is offline   Reply With Quote
Old 04-08-2010, 08:06 PM   #5
Rewards Points: 162
I've always used 2 ton = 1 CY of gravel as a rough estimate. It will vary depending on if you are ordering clear stone or a TB. Since you are putting down base for paving, I'm assuming you are using TB.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 04-08-2010, 10:08 PM   #6
2 threads on the same topic merged
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 03:30 AM
