-   -   How to calculate how much rock fill and asphalt to order? (http://www.diychatroom.com/f16/how-calculate-how-much-rock-fill-asphalt-order-68565/)
Negativecreep0 04-08-2010 08:29 AM
Hey guys I have a large mud pit in the middle of my Scrap Yard that I want to fill in with 1.5" stone and then do a layer of blacktop over that
how can I calculate how much (in tons) of stone and blacktop I need to fill this area
the area is 50 ft x 75 ft, and I have been told I should do a minimum of 8" of rock fill............. thanks
tpolk 04-08-2010 09:11 AM
the quarry can give you cubic yrd to tonnage for type of stone you choose
GardenConcepts 04-08-2010 06:33 PM
length x width x height/27 = cubic yards. Cubic yards x 1.25 will give you the approximate tons of gravel. Different types of stone have different weights, so this will vary. 50 x 75 x .66 = 2475/27 = 91.6 cubic yards x 1.25 = 114.58 tons.
I don't know what asphalt weighs, but you can calculate cubic yards the same way and call a quarry that makes asphalt. Typical asphalt is 2" base coat and 2" topcoat. Of course, you could go thicker for heavy equipment.
bob22 04-08-2010 06:38 PM
See:
http://www.weldonmat.com/calculators.htm
about halfway down page.
I put your dimensions in and it came back with 131 tons. Seems like a lot to me.
stubborn1 04-08-2010 07:06 PM
I've always used 2 ton = 1 CY of gravel as a rough estimate. It will vary depending on if you are ordering clear stone or a TB. Since you are putting down base for paving, I'm assuming you are using TB.
Scuba_Dave 04-08-2010 09:08 PM
2 threads on the same topic merged
