Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-29-2012, 03:11 PM   #1
How to add a sprinkler valve???
I could only find one entry in the search for this topic and it was not very clear. I need to add a sprinkler valve to an existing run of valves?
Do I just add it in at the end of the run?
Thank you for your help.
apadulo is offline   Reply With Quote
Old 01-29-2012, 03:25 PM   #2
sdsester's Avatar
I assume your valves are stacked up together in some sort of manifold configuration right?
If this is the case, you can add another along the water supply line either in front or at the end of that manifold---wherever you have room. Try to minimize laying your pipe runs out of the valves over each other though.
Your challenge may be adding to the PVC ts and elbows if that is what the manifold piping is made from. If the current manifold end with a PVC elbow, you will not have anything to glue on to. You may end up having to rebuild the whole thing which is no big deal but will cost you some fitttings to rebuild the manifold and hook up again to the sprinkler lines. You will need to measure carefully.
Now is a good time to think about adding a shut-off valve for the whole system if there isn't one too! And and air compressor inlet if you need to blow your system out in a freezing climate. If your pressure is excessive you might as well added a pressure regulator too when the water is off.
Make sure the anti-syphon/backflow portions of the valves are high enough to do their thing. I see a lot of DIY systems with them too low to really meet code if anybody were to look.
sdsester is offline   Reply With Quote
Old 01-29-2012, 07:03 PM   #3
Msradell's Avatar
A picture of how your existing valves are situated would be very helpful.
Msradell is offline   Reply With Quote
Old 02-03-2012, 07:21 PM   #4
Do you have an extra colored wire so that you can wire it into the controller
jasonreck71 is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
sprinkler valve chubbyhubby Landscaping & Lawn Care 0 04-26-2010 06:16 PM
Sprinkler System - Installing Valve Box tazmajazz Plumbing 3 01-06-2009 10:14 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
sprinkler valve leaks deck hand Landscaping & Lawn Care 3 06-20-2008 09:36 PM
