Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-14-2010, 03:31 PM   #1
Send a message via ICQ to guardmp
Cool
How to add concrete to an irrigation ditch
I have an irrigation ditch that runs the length of my home and I have issues with over-grown weeds in the ditch. I want to pour concrete the entire length; how do I concrete this V-ditch properly?
guardmp is offline   Reply With Quote
Old 02-14-2010, 04:42 PM   #2
sdsester's Avatar
Depending on what size ditch you have? I would look into prefabbed systems or at least systems for the concrete forms. Here is one possibility:
http://www.trenchdrain.net/polyself.htm
There will certainly be concrete sectional things or tile sorts of systems. Just need to google around for a bit. Hat to see you have to form the thing yourself for a pour if there is something already pre-made that will work for you.
sdsester is offline   Reply With Quote
Old 02-14-2010, 08:01 PM   #3
Pics or dimensions would help to get a better idea of what your working with. Either way you will need to dig down enough to compensate for the height of the concrete. I would definitely look around for some prefab slabs or system. You might be able to look into a metal or plastic culvert system. You can also cut them in half instead of completely enclosed. In my city I would have to get a permit from the city if it ran through my property to another property. I attached a pic of a culvert I found on the web.
william duffer is offline   Reply With Quote
Old 02-22-2010, 12:48 AM   #4
Round-up for getting rid of the weeds.
Old 02-22-2010, 07:32 PM   #5
Don't know it all, yet!
Nope! Soil sterilant. Round-Up will kill what is there, but will not prevent anything from coming back in.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 02-22-2010, 08:20 PM   #6
Master General ReEngineer
Bondo's Avatar
Ayuh,... depending on the grade,+ run,...
A Weedwacker could be the Best Idea....
Old 02-22-2010, 09:01 PM   #7
Agreed - but over the years I have used Round-up, I find I need only to reapply a couple three times a years to acheive a high level of control.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
